ListBox column width in resource file ignored
When I create an application within MicroStation, I define the dialog layouts in a resource file (.r).
A multi-column listbox is defined by means of a DItem_ListBoxRsc where each column has 4 parameters:
  • Column width
  • Max size
  • Attributes
  • Heading
It seems that since the Connect Edition, the specified column width is ignored and the application simply takes the width of each column as within a previous exection: When a manually change the column width by dragging the header left or right and then close and reopen the application, the column widths appear as within the previous run.
I can still programmatically adjust the width by calling the mdlDialog_listBoxSetColInfo API.
The previous edition (MicroStation V8i) did not act like this.
Has anyone had the same experience?
Robert
