[MStn CE U15.2 C#] Bug? To modify a cell content does not work...
based on a recent question I thought what is a simple working code structure to iterate and modify a cell content.
This topic was discussed several times, but usually for C++ API. And when for NET, not many clear answers were provided. Because C++ and NET APIs are implemented differently a bit (which makes sense, C++ iterator and C# enumerator are different animals ;-), so not everything can be copied 1:1.
I wrote two snippets (simplified versions, e.g. without proper disposal, are shared), one inspired by 's answer in this discussion, the second one put together from more sources. But they do not work :-(
Test workflow is based on the attached DGN:
  1. Identify an element from a cell (line string)
  2. Obtain a parent element (cell element header)
  3. Find a line that is in wrong level (level named "circles")
  4. Change the element level to the right one ("lines")
  5. Write the modification back to DGN file
Snippet 1:
Element parentElement = selected.ParentElement;
CellHeaderElement cellToBeModified = parentElement as CellHeaderElement;
CellHeaderElement originalCell = Element.GetFromElementRef(cellToBeModified.GetNativeElementRef()) as CellHeaderElement;
ChildElementEnumerator children = new ChildElementEnumerator(cellToBeModified);
while (children.MoveNext())
    if (children.Current is LineStringElement)
        Element originalElement = Element.GetFromElementRef(children.Current.GetNativeElementRef());
        ElementPropertiesGetter getter = new ElementPropertiesGetter(children.Current);
        if (getter.Level == this.levelCircle.LevelId)
            ElementPropertiesSetter setter = new ElementPropertiesSetter();
            setter.SetLevel(this.levelLines.LevelId);
            bool status = setter.Apply(children.Current); // true returned, instance changed
            // Bentley.DgnPlatformNET.DgnPlatformNETException: 'Bad StatusInt: 69645
            // children.Current.ReplaceInModel(originalElement);
// Test, whether modified cell was really modified ... not, it still contains original element
cellToBeModified.ExposeChildren(ExposeChildrenReason.Query);
bool exposeResult = cellToBeModified.ExposeChildren(ExposeChildrenReason.Query);
ChildElementCollection childrens = cellToBeModified.GetChildren();
// Bentley.DgnPlatformNET.DgnPlatformNETException: 'Bad StatusInt: 32768'
// cellToBeModified.ReplaceInModel(originalCell);
Snippet 2:
cellToBeModified.ExposeChildren(ExposeChildrenReason.Edit);
bool exposeResult = cellToBeModified.ExposeChildren(ExposeChildrenReason.Edit); // true returned
ChildElementCollection children = cellToBeModified.GetChildren();
foreach (Element component in children)
    if (component is LineStringElement)
        Element original = Element.GetFromElementRef(component.GetNativeElementRef());
        ElementPropertiesGetter getter = new ElementPropertiesGetter(component);
            bool status = setter.Apply(component);
            // Bentley.DgnPlatformNET.DgnPlatformNETException: 'Bad StatusInt: 69645'
            // component.ReplaceInModel(original);
I do not know whether I do not understand API right, so the code is wrong, or there is a bug in API implementation.
With regards,
  Jan
N014 cell modification.dgn
