I need to set center point(0,0) for specifc latitude and longidute (N50:01:59.9 E08:34:13.64).
To achive this I create new GCS and set the following properties.
pCus_GCS->SetStandardParallel1(DStdPrll); pCus_GCS->SetCentralMeridian(DCenMer);
At the end when I place cell at location N50:01:59.9 E08:34:13.64 the X value is 0 but Y value is not.
At picture below you can see result. My question is. What to do to set point 0,0 to location N50:01:59.9 E08:34:13.64 ?
Edit: Point 0,0 is at location S00:00:00 E008:34:13.64. So I need to set latitude somehow.
Damian Holubowski
Hi Damian,
are you able to obtain the results you need manually? To set custom GCS and to do the transformation? Just to evaluate whether the problem is in the code or somewhere else.
With regards,
Jan
Hi Jan,
ACS Triad shows X,Y = 0,0
To get point at location i use this:
DgnGCS cs = DgnGCS.FromModel(dgnModel, true); cs.UorsFromLatLong(out point, originGeoPoint);
originGeoPoint is N50:01:59.9 E08:34:13.64 and i want my cell to be at ACS triad marker. It's not coding issue. GCS can be set manually in microstation itself. I tried all latitude setting and now I try with False northing value.
