How to cancel save/auto-save action through API?
I am trying to cancel some actions (ex. File->Save, File->SaveAs, File->print, File->close).
I can able to block other commands in above except File->Save. While blocking save action, the modifications are getting saved.
After MS_DGNAUTOSAVE set to 0, modifications not saved. How to block autosave action through programmatically.
InputFilterReturnValue monitorFunction(Inputq_element* queueElementP)
	if (queueElementP != NULL)
		if (queueElementP->u.cmd.command == File_Save)
			return INPUT_REJECT;
	return INPUT_ACCEPT;
In above code File_Save is commandid of File->Save action.
Rajesh Varatharajan
