I would like to get reference clip boundary in a MicroStation Connect VBA macro
Many thanks for your help
Rémy
Hi Remy,
It has been a long time since I was dabbling with reference clips in MVBA, though I believe most of this code can be used as a starting point and help though it may need some minor tweaking to ensure it works in CONNECT to run and provide proper/expected results.
Option Explicit #If VBA7 Then Declare PtrSafe Function mdlRefFile_getInfo Lib "stdmdlbltin.dll" (ByVal modelRef As Long) As Long #Else Declare Function mdlRefFile_getInfo Lib "stdmdlbltin.dll" (ByVal modelRef As Long) As Long #End If Private Const DISCONNECT = 1.79769313486231E+308 'msdefs.h:327:#define DISCONNECT (1.7976931348623157e308) Private Const Debug1 = True ... Sub ProcessAttachmentClips(oAtt As Attachment) ' Get reference clip pointer, else exit Dim ReferenceFileP As Long ReferenceFileP = mdlRefFile_getInfo(oAtt.MdlModelRefP) If ReferenceFileP = 0 Then Exit Sub ' Get reference clip count and pointer Dim elID As DLong Dim bIsDisconnect As Boolean, bIsStartPt As Boolean Dim oStartEndPt As Point2d, oDisconnect As Point2d Dim oPoint As Point3d Dim lShapeIdx As Long Dim lNumPoints As Long ' < 4, or > 2500: MDLERR_INVALIDCLIP Dim strExpression As String, sMessage As String strExpression = "((struct referenceFile *)" & ReferenceFileP & ")" lNumPoints = GetCExpressionValue(strExpression & "->clip.clip_vertices") If Debug1 Then Debug.Print "NumPoints: " & lNumPoints & ", ElID: " & DLongToString(elID) oDisconnect = Point2dFromXY(DISCONNECT, DISCONNECT) ' Load point2d array with reference clip boundary and masks Dim I As Integer Dim arr() As Point2d, oCurrPt As Point2d ReDim arr(0 To lNumPoints) lShapeIdx = 0 bIsStartPt = True For I = 0 To lNumPoints - 1 ' Add current reference clip point to array arr(I).x = GetCExpressionValue(strExpression & "->clip.clipP[" & I & "].x") arr(I).Y = GetCExpressionValue(strExpression & "->clip.clipP[" & I & "].y") oCurrPt = arr(I) sMessage = "" ' Identify special points: Disconnect point and matching start and end points for clip masks. bIsDisconnect = Point2dEqual(oCurrPt, oDisconnect) If bIsDisconnect Then sMessage = "[DISCONNECT POINT]" bIsStartPt = True lShapeIdx = 0 Else If bIsStartPt Then oStartEndPt = oCurrPt End If bIsStartPt = Point2dEqual(oCurrPt, oStartEndPt) If bIsStartPt Then lShapeIdx = lShapeIdx + 1 If (lShapeIdx Mod 2) = 0 Then sMessage = "[END POINT]" bIsStartPt = True lShapeIdx = 0 Else sMessage = "[START POINT]" bIsStartPt = False End If End If ' Print RAW clip point data Debug.Print vbTab & "RAW: " & MSUtils.Point3dToString(Point3dFromXY(oCurrPt.x, oCurrPt.Y)) oPoint.x = oCurrPt.x / ActiveModelReference.UORsPerMasterUnit oPoint.Y = oCurrPt.Y / ActiveModelReference.UORsPerMasterUnit ' Print clip point transformed by ActiveModelRef UORsPerMasterUnit Debug.Print vbTab & "UORsPerMasterUnit: " & MSUtils.Point3dToString(oPoint) Dim oTransPt As Point3d Dim tMastToRef As Transform3d 'tMastToRef = oAtt.GetReferenceToMasterTransform tMastToRef = oAtt.GetMasterToReferenceTransform oTransPt = Point3dFromTransform3dTimesPoint3d(tMastToRef, oPoint) 'oTransPt.x = oPoint.x '/ ActiveModelReference.UORsPerMasterUnit 'oTransPt.y = oPoint.y '/ ActiveModelReference.UORsPerMasterUnit ' Print clip point transformed by ActiveModelRef UORsPerMasterUnit Debug.Print vbTab & "MasterToReferenceTransform: " & MSUtils.Point3dToString(oTransPt) 'CreatePointLine oTransPt 'oPoint End If Debug.Print "Point(" & I & ")" & vbTab & ".x: " & oCurrPt.x & ", .y: " & oCurrPt.Y & vbTab & sMessage Next End Sub
HTH,Bob
Rémy Weill said:I would like to get reference clip boundary
Here's an example for V8i.
Many thanks Robert and Jon
After some attempt, and according to This topic
It seems not so obvious to access to the members (in that case the clip object) of the reference file structure from connect edition VBA but I will continue to try
