$dgn=$objustn.OpenDesignFile('C:\x.dgn') $objustn.CadInputQueue.SendKeyin('fit all') $objustn.CadInputQueue.SendDataPoint <<variablePoint3d>> #void SendDataPoint (Point3d, Variant, int)
how to declare a Point3d variable named "VariablePoint3d" and assign x,y,z values to this in PowerShell.
Not sure what the input needs to be but you could record a macro doing what you need and convert to VBA. That will give you the code you need.
Also, "false" is spelt incorrectly in your code sample.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Thank you Chris.
Vinoth Joseph
ATKINS
Bangalore, India
Vinoth Joseph,
This question should have been posted in one of the MicroStation forums. PWPS_DAB has very limited functionality with MicroStation.
Hi Dan, I'm not sure how to move this post to Microstation forums. Any lead please.
I will look into getting this moved. It isn't a "problem", but obviously more MicroStation savvy folks would see posts like this and then more likely one or more responses.
Thanks, Dan.
Hi Vinoth,
Vinoth Joseph said:I'm not sure how to move this post to Microstation forums. Any lead please.
use More > Move tool available under your original post.
With regards,
Jan
Hi Jan, I moved this question to Microstation Forum.
Vinoth
Vinoth Joseph said:declare a Point3d variable named "VariablePoint3d" and assign x,y,z values to this in PowerShell
Try something like this...
$objustn.CadInputQueue.SendDataPoint ($objustn.Point3dFromXY(1,2))
Thanks, Jon.
I tried as you suggested. but it throws an error.
$objustn.CadInputQueue.SendDataPoint($objustn.Point3dFromXYZ(0,0,0)) The specified record cannot be mapped to a managed value class. At line:1 char:1 + $objustn.CadInputQueue.SendDataPoint($objustn.Point3dFromXYZ(0,0,0)) + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : OperationStopped: (:) [], ArgumentException + FullyQualifiedErrorId : System.ArgumentException
