I have this code below working in an MS_INITAPP for MicroStation CONNECT edition update 15, but running it in MicroStation V8i in an entirely new project for.NET 3.5, I am seeing the following error:
No design file is active at Bentley.Interop.MicroStationDGN.Application.OpenDesignFile(String DesignFileName, Boolean ReadOnly, MsdV7Action V7Action)
Source code:
private Bentley.Interop.MicroStationDGN.Application app; protected override int Run(string[] commandLine) { app = Bentley.MicroStation.InteropServices.Utilities.ComApp; app.Visible = false; ... ... DesignFile designFile = app.OpenDesignFile(document.Path, true, MsdV7Action.UpgradeToV8); ... }
The C# .NET35 project for the MicroStation V8i project has all the dll references to the V8i versions as seen below which differs from the CONNECT Edition:
Bentley.Genral.1.0
bentley.interop.microstationdgn
bentley.microstation
Bentley.MicroStation.General
bentley.microstation.interfaces.1.0
ustation
HI Mervin,
Mervin Bowman said:I have this code below working in an MS_INITAPP for MicroStation CONNECT edition update 15
I recommend to do not share V8i and CE code, even "mentally" only. They are different products with different APIs, so it's better to think about V8i version as about newly written, for different product ;-)
Mervin Bowman said:Source code:
It does not tell everything. How Addin attributes are defined?
I recommend to start with some working example (e.g. provided in this discussion, but I remember it was discussed and code shared several times) and step by step to modify it to meet your requirements.
With regards,
Jan
Hi Jan,
Thanks for the reference. I was able to figure out why V8i was not opening the file - To start MicroStation I originally had the command:"ustation.exe -WAaddinName"
But, due to the fact that I was not opening a drawing file, V8i was sending that error back of "No design file is active".
Adding a drawing file to the command it seems to be working now
"ustation.exe -WAaddinName <path to file>"
There was a comment in that post that mentioned - if there is no file active in MicroStation V8i, it will exit.
Answer Verified By: Robert Hook
