[CONNECT Update 15 C++] ScaleRotateTextCell example crashes when clicking any function button on it, am I using it wrong or is it bugged?
It is a example under C:\Program Files\Bentley\MicroStationCONNECTSDK\examples\Elements\ScaleRotateTextCell
I can successfully bmake (\ScaleRotateTextCellbmake -a  ) the example and load it via utility.
but crashes the microstation program when clicking the  Origin rotate text&cell  and  Origin scale text&cell  function.
The  Active scale by 3 points  and  Active rotate by 2 points  only responds but does not work by scaling nor rotating any selected element/object/model/text.
and only the  undo  button works, which by clicking it undo any globally performed action.
Please tell me what could be done to make this example work? Help is much appreciated.
Parents Reply Children
