Hello, I want to create Design Links (not the ‘engineering links’) to some Elements that are in a CellElement. Here in the forum I found just a command "ELEMENT CREATE LINK URL xxx" which is only working on a selected Element. Unfortunately I could not find any API or examples to that topic. Is that possible to create the DesingLinks with for example an ElementID or elementRef in V8? Thanks and Regards! Lukas
Lukas Sikora said:I could not find any API or examples [about Design Links]
The MicroStation V8i API won't help you. But, with MicroStation CONNECT you can find the DgnLinkManager class in the C++ MicroStationAPI: The Drawing Set interface allows programs to manipulate drawing sets and drawing links stored in dgn idx files.
DgnLinkManager
I can't see anything similar in the DgnPlatformNet API.
Answer Verified By: Robert Hook
Thanks Jon! I was hoping that there is something that I couldn't find. In the CONNECT there are more possibilities but unfortunately I need that for the V8i. Regards, Lukas
Just as Jon mentioned, there is no public APIs for the design link in V8i. Below example is for CE.
void addDgnFileLink(WCharCP unparsed) { ElementHandle eh(2733L, ACTIVEMODEL); //Here MUST use ElementHandle if (!eh.IsValid()) { mdlDialog_dmsgsPrint(L"ElementHandle is invalid."); return; } DgnLinkTreeSpecPtr spec = DgnLinkManager::CreateTreeSpec(eh); DgnLinkTreePtr linkTree = DgnLinkManager::ReadLinkTree(*spec, true); DgnLinkTreeBranchR root = linkTree->GetRootR(); StatusInt status; auto leaf = DgnLinkManager::CreateLink(status, DGNLINK_TYPEKEY_File); DgnDocumentMonikerPtr moniker = DgnDocumentMoniker::CreateFromFileName(L"C:\\temp\\test.dgn"); DgnLinkP link = leaf->GetLinkP(); DgnFileLinkP fileLink = dynamic_cast<DgnFileLinkP>(link); fileLink->SetMoniker(moniker.get(), true); WString name = link->BuildSuggestedName(&root, true); WString uniqueName = root.GetUniqueChildName(name.GetWCharCP()); leaf->SetName(uniqueName.GetWCharCP()); root.AddChild(*leaf, 0); DgnLinkManager::WriteLinkTree(*linkTree); }
