Need help with vb.net ustation.dll pinvoke declaration
Any suggestions on how to get the mdlSystem_setBatchProcessingState (ustation.dll) pinvoke declaration to work in vb.net?  I keep getting the "Unable to load DLL 'ustation.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)" error, regardless of how I change the code.
Apparently this means that the DLL is found, but unable to load.  I am unable to find the "mdlSystem_setBatchProcessingState" method in ustation.dll using dnSpy or ildasm.  I thought perhaps there is a dependency problem, so I ran the dependency walker... however there 571 missing files (most look like "EXT-MS-WIN-*.DLL).  I find it hard to believe that I would have to resolve all of these prior to using the .dll.
All of my projects are 64 bit.  Everything compiles and works just fine prior to trying to use this method.  Note that all other code is using the non-pinvoke .net methods.
If there is another way of entering batch processing using vb.net (no pinvoke) that would also work.  That would actually be preferable.
Thanks for your time.
Here are some various ways that I've tried:
<DllImport("ustation.dll", EntryPoint:="mdlSystem_setBatchProcessingState")>
Public Shared Sub mdlSystem_setBatchProcessingState(
ByVal procState As Long,
ByVal s As IntPtr)
End Sub
Friend Declare Auto Sub mdlSystem_setBatchProcessingState Lib "ustation.dll" (
ByVal s As IntPtr)
Parents Reply Children
