The SDK delivers .NET example DgnEC\PickListProviderExample. I can build that example successfully. However, I don't understand what it does. The two commands have little visible effect. The AddIn has a WPF user interface, but neither command shows that interface. What have I missed?
Perhaps the ReadMe file could be expanded with a better explanation?
Hi Jon,
Jon Summers said:What have I missed?
did you read blogs about PickList API?
I think they provide good overview about PickList API.
Jan
Jan Å legr said:I think they provide good overview about PickList API
I have written code that uses the PickList API. The PickList API is not my question.
My question is about a particular example, and what it is supposed to demonstrate. After loading the example AddIn and invoking its commands, nothing appears to happen.
Have you investigated the PickListProviderExample?
Hi Jon Summers,
Thank you for bringing both these items to our attention.Bob
Answer Verified By: Jon Summers
Robert Hook said:I need to review then publish for that I will update a link to the new related blog
Thanks: that clarifies the SDK example!
Robert Hook said:See: [MSCE U16 C#, C++] Create custom PickListProvider for PickList values
Excellent!
