this post here,
(+) Add new EC Symbol provider with custom symbol sets using Managed API's - MicroStation Programming Blog - MicroStation Programming - Bentley Communities
talks about how to create your own symbol providers. apart of that is documenting the symbol provider. there is a method in the above linked post called DocumentSymbols. and it is reading in an xml file. but the xml file was not posted with post.
So im looking for what that format should be for that file or if there is an example file somewhere. anything to point me in the right direction??
Hi John,
in addition to Yongan.Fu' answer, did you check SymbolProvider example, delivered with MicroStation SDK? E.g. in \examples\DgnEC\SymbolProviderExample\ManagedExample example, it's shown how xml file should looks like.
Jan
Answer Verified By: John Drsek
Thanks Jan,
Not sure how i missed that. looks like i only checked the ORD sdk examples and not the Microstation sdk ones. thats my bad. that example had what i needed to see to get the documentation working.
