bmake lets us define a C++ compiler switch like this...
nameToDefine=_UNICODE %include $(MDLMKI)cdefapnd.mki
Macro MDLMKI points to the SDK \mki folder.
MDLMKI
\mki
Those lines mean...
_UNICODE
nameToDefine
cdefapnd.mki
-d_UNICODE
A similar idiom lets us define an include folder for the C++ compiler...
dirToSearch = $(geometry) %include $(MDLMKI)cincapnd.mki
Are similar macros available to define switches for the Microsoft resource compiler? I ask because I'm looking at moving to Viz Studio 2019. Unfortunately the Viz Studio 2019 resource compiler is broken and doesn't look in the right folder to find Microsoft header file afxres.h. I can fix the problem by hard-wiring the path to that file in the project resource (.rc) file...
afxres.h
.rc
#include "C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/atlmfc/include/afxres.h"
I'd prefer not to do that. If a resource compiler switch were available, I could write something akin to the dirToSearch lines above. Or is there another way to define Microsoft resource compiler options?
dirToSearch
Microsoft describes their resource compiler (RC.exe) and its command-line switches here.
RC.exe
Note: in case it's not obvious, this question is about using bmake to control the Viz Studio resource compiler. I'm not asking about the MDL resource compiler.
Hi Jon Summers,
From what I can tell (findings below) after calling mdl.mki you *may* be able to influence (update or append additional) include path(s) to mfcInc that would be used to define the atlmfc folder location where afxres.h resides. If needed you may want to run bmake with verbose logging (+avilC) and capture output to a build log to verify how successful this can influence the process. Also, MSCE U16.1 SDK supporting VS2019 should be available in the coming weeks if this could wait or, the suggested does not pan out.
HTH,Bob
Every MDL application using bmake and respective MKI files should first include: %include $(MDLMKI)mdl.mki Where mdl.mki includes/calls(">") additional mki files that further define respective platform and compiler specific: Macros, Cmds, and Locations/Paths. Given that, the path (and macro variables) to define the ATL include folder is constructed as... Mdl.mki > ConfigurePolicy.mki > AssertToolSet.mki - Sets MSVCDir=VCToolsInstallDir AssertToolSet.mki > winntmdl.mki - Sets ntTools=$(MSVCDir)/ - Sets mfcInc = ${ntTools}/atlmfc/include/ /* ATL Includes */ Given that, if you were to inspect and/or redefine mfcInc after calling MDL.MKI you (theoretically) should be able to override and/or append your own path(s).
Robert Hook said:From what I can tell (findings below) after calling mdl.mki you *may* be able to influence (update or append additional) include path(s) to mfcInc that would be used to define the atlmfc folder location where afxres.h resides
The problem is that the include .mki macros set switches for the C++ compiler. Those don't affect Microsoft's resource compiler.
.mki
This is a guess but in winntmdl.mki are the lines.
.rc.res: $(msg) rc $(rcOpt) -d$(rcCPU) -dwinNT $(ProductRcIncludes) $(rcExtraOpts) -r -fo$@ $%$*.rc ~time
Which I think execute rc.exe, you should be able to append to either rcOpt or rcExtraOpts to do what you need ?
Paul
Answer Verified By: Jon Summers
Paul Chater said:In winntmdl.mki are the lines
Thanks for the hint. This is what I added to my bmake file...
# Beware of line-wrapping atlmfc = "C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC /Tools/MSVC/14.29.30133/atlmfc/include" rcExtraOpts + -i $(atlmfc)
First, we define a macro atlmfc that specifies a folder. Note these details...
atlmfc
VC
/Tools
Next we append the include (-i) switch with the folder macro (atlmfc) to macro rcExtraOpts.
-i
rcExtraOpts
When we invoke the make rule in the bmake file then the include file you mention (winntmdl.mki) uses the macro (rcExtraOpts) defined above...
winntmdl.mki
$(tempObjects)Annotator.res : $(baseDir)Annotator.rc $(baseDir)resource.h
When we build the project bmake emits the following...
[== Building Q:\CONNECT\Annotator\MasterPlanner\objects\MasterPlanner\Annotator.res, (Q:\CONNECT\Annotator\MasterPlanner\Annotator.rc) ==] rc -d -dVARIETY= -dUSER="\"CONNECT on CELERATRIX64\"" -d_X64_ -dwinNT -i "C:\Program Files (x86)\Microsoft Visual Studio\ 2019\Community\VC\Tools\MSVC\14.29.30133\atlmfc\include" -r -foQ:\CONNECT\Annotator\MasterPlanner\objects\MasterPlanner\Annotator.res Q:\CONNECT\Annotator\MasterPlanner\Annotator.rc Microsoft (R) Windows (R) Resource Compiler Version 10.0.10011.16384
The include switch (-i) is the blue text.
