i am unable to download Microstation v8i Select Series 10 SDK. The Link on SDK Releases on Bentley website takes me to Downloads but unable to proceed further.
Prateek
Hi Praatek,
may I ask you why do you pollute the forum asking for the same thing three times? It does not looks like professional behavior.
You also did not provide too much information, because formulations like "Link on SDK Releases" do not tell too much. Why do you not share e.g. screen capture, or exact URL where you encounter problem? Also, you did not tell anything whether you have enough access rights (software download) and whether you are BDN member.
With regards,
Jan
Hello Jan,
Apologies for if it was perceived as unprofessional behavior, however it was because after submitting question on forum the website crashed and when I tried to search back I could not find my post again. So I was under the impression that the question was not posted. Later I did raise the question via Service Request and got the required answer. Thank you
