Hi
I would like to set the ElementLineStyle (using standard linestyles 0-7) for a new level. It should be a quite simple task but I got some troubles.
LevelId lvlID = ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->ComputeHighestUsedLevelId(); EditLevelHandle elh = ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->CreateLevel(L"TestLayer", 555, lvlID + 1); LsEntryCP ls = LineStyleManager::ResolveLineStyle(3, ISessionMgr::GetActiveDgnModelRefP()->GetDgnFileP()); if (ls != NULL) { lifalib_dmsg("Name = %ls", ls->GetStyleName()); elh.SetByLevelLineStyle(*ls, NULL, *ISessionMgr::GetActiveDgnModelRefP()->GetDgnFileP()); } else lifalib_dmsg("NULL..."); ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->Write();
My problem is that LineStyleManager::ResolveLineStyle returns NULL.
Is there another way to set the linestyle for a level ?
I've tried to use the MDL funktion mdlLevel_setElementStyle and it works just fine when working in a "normal" active design file, but some of our users often work in a model from a reference file that is "activated". In that case I have to store the fileLevelCache using:
Then I can set the linestyle for the level and it seems to work just fine, but the linestyle is not saved even though that I use
mdlLevelTable_rewrite(mdlModelRef_getActive());
and / or
Any ideas ?
Regards, Evan
Could you please try with following MDL function to set Line Style on Level element:MSCORE_EXPORT StatusInt mdlLevel_setElementSymbology(DgnModelRefP modelRefIn,LevelId levelIdIn,UInt* colorIn,int* styleIn,LineStyleParams* styleParamsIn,UInt* weightIn)
Hi Sagar
Thank you very much for your reply.
I've just tested it, but the result is the same as using mdlLevel_setElementStyle
What parameters are you passing in? Are you setting styleIn to a value between 0-7 before passing it to the function mdlLevel_setElementSymbology() ?
Can you provide a sample project wherein the said problem is reproducible?
If I use these few lines of code:
EditLevelHandle elh = ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->CreateLevel(L"TestLayer", 555, LEVEL_NULL_ID); LevelId lvlID = elh.GetLevelId(); int ls = 3; ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->Write(); mdlLevel_setElementStyle(ISessionMgr::GetActiveDgnModelRefP(), lvlID, &ls, NULL); ISessionMgr::GetActiveDgnModelRefP()->GetFileLevelCacheP()->Write();
then the level is created and the ByLevel is set correctly, but as mentioned earlier the new linestyle is not saved when you work in an "activated" reference file...
Hello EvanH,
There is an equivalent function SetByLevelLineStyle(LevelDefinitionLineStyle const&); in C++ but it doesn't expose yet. When I add it manually into below LevelCache.h file, we can use the same code as Jon's C# to implement your requirement by C++.
LevelCache.h
void setLinestyleForLevel() { DgnFileP pDgnFile = ISessionMgr::GetActiveDgnFile(); FileLevelCacheR lvlCache = pDgnFile->GetLevelCacheR(); EditLevelHandle elh = lvlCache.CreateLevel(L"TestLayer", LEVEL_NULL_CODE, LEVEL_NULL_ID); LevelDefinitionLineStyle ldls(3, NULL, pDgnFile); elh.SetByLevelLineStyle(ldls); elh.SetByLevelWeight(5); lvlCache.Write(); }
Answer Verified By: EvanH
