I use microstation 08.11.09.578, DGN 2D V7 Upgrade V8
I want to get the 2D coordinates of the element, I see the manual but don't see the method 'Point2dFromXY'
Point2dFromXY Method Returns a point with specified x and y components. Syntax Point2d = object.Point2dFromXY (X, Y)
Mine is an array
What assembly do you reference? I think your project is wrong, as it looks like your reference COM directly, not MicroStation interop assembly.
Jan
Yes it is a COM portCan I see your reference?
ba ranh said:Can I see your reference?
No. I maintain (only) several my old V8i projects now (because V8i is not supported product now), and none from them is external application, because it just not make any sense to make life harder and more limited, comparing to standard MicroStation addin.
Search this web, it was discussed several times, and I think some code was shared too.
But, what is difficult on referencing Interop assembly?
