Both the DgnPlatformNet and the MicroStationAPI help documents provide terse information about the TextBlock class.
TextBlock
Concealed in the MicroStationAPI help document are some examples that show how to use the TextBlock API. However, they are cunningly hidden in the section deprecated10_0.fdf File Reference, where no one would intuitively search. Whose idea was that?
Could TextBlock example code be moved from deprecated10_0.fdf File Reference to the primary TextBlock section?
Hi Jon Summers,
I can see if we can have that (recommended upgrade) moved to a better (code snippet) location then referenced from the deprecated section. I will update here once I file the Backlog Item ("BLI", p.k.a. "enhancement").
Thank you for the feedback,Bob
Answer Verified By: Jon Summers
