I need to make certain configurations on the system when workspace load, so creating a C# DLL that should reside in workspace and run as soon as the workspace loads in OPM. I have created a C# DLL with KEYIN, but don't know how to configure this DLL in workspace, and this DLL should run when workspace is loading on OPM.
Varsha
Hi Varsha,
Varsha Reddy said:I need to make certain configurations on the system when workspace load, so creating a C# DLL that should reside in workspace
can you provide more details what your application does and what you want to achieve? When "certain configuration" is required, it is a role of workspace/workset, not an application / addin.
Varsha Reddy said:and run as soon as the workspace loads in OPM.
I agree with Jon Summers this is not "the good wish".
I see two problems there:
Varsha Reddy said:and this DLL should run when workspace is loading on OPM.
The variables, mentioned by Jon, are "standard ways" you can use, depending on the required functionality.
There are also other variables available (e.g. _USTN_FIRSTDGNFILE), but they are not documented and are used by MicroStation itself.
With regards,
Jan
