I am attempting to export my MVBA projects as text files. I was able to get the .bas, .cls, and .frm files to export, but I am struggling with how to make the .frx file text, and how to export the project references. (Declaring Dim oRef as Reference throws a user-defined type not defined error) I used this article as a reference: https://communities.bentley.com/products/microstation/w/microstation__wiki/2889/2889
Full code here:
Public oComp As Object Public index As Integer Public filePath As String Public fileName As String Public fullfileName As String Public fsoOutputFile As TextStream Public Sub Finish() Dim projName As String Dim suffix As String Dim filetype As String Dim oRef As Reference filePath = "U:\Carl_Stanton\microstation_vbas" Set oVBE = Application.VBE Set objFSO = CreateObject("Scripting.FileSystemObject") For Each oProject In oVBE.VBProjects projName = oProject.Name If doesFolderExist(filePath & "\" & oProject.Name) = False Then MkDir (filePath & "\" & projName) End If Call SetOutputFile(filePath & "\" & projName, projName & "_refs.txt") Set refsFile = objFSO.OpenTextFile(fullfileName, ForWriting, True) For Each oRef In oProject.References refsFile.WriteLine (oRef.FullPath) Next For Each oComp In oProject.VBComponents filetype = oComp.Type Select Case oComp.Type Case "1" suffix = ".bas" Case "2" suffix = ".cls" Case "3" suffix = ".frm" End Select Call SetOutputFile(filePath, oComp.Name & suffix) fileName = filePath & "\" & projName & "\" & oComp.Name & suffix oComp.Export (fileName) Next index = 1 Next MsgBox ("extract complete") End Sub Public Sub Start() UserForm1.Show End Sub Public Function doesFolderExist(folderPath) As Boolean doesFolderExist = Dir(folderPath, vbDirectory) <> "" End Function Public Sub SetOutputFile(file_path As String, file_name As String) fullfileName = file_path & "\" & file_name If objFSO.FileExists(fullfileName) Then 'you delete if you find it' objFSO.DeleteFile fullfileName, True End If End Sub
Why are you doing the export?
Can't you just copy the .mvba file and then rename the project?
Rod WingSenior Systems Analyst
I want to export to text so I can put the text files into version control and be able to see the diffs.
Carl Stanton said:I want to export to text so I can put the text files into version control
VBA is ancient. It isn't really suited to version control. It's VB 5½, invented by Microsoft a long time ago. VBA was first launched with MS Excel 5.0 in 1993. That was before version control became commonplace.
What version control will you use? Can't it check binary files as well as text files?
In the long term it would pay to move to another language more amenable to document management. C# and C++ are both good languages for MicroStation CONNECT development and lend themselves to version control.
the VBA's that I am exported are used to create custom item groups in Microstation. I assume I could do the same thing with c#?
