I've installed the Microstation CE SDK and the buildallexample.bat is not running properly. Here's an example of the output I get when running the bat:
C:\PROGRA~1\Bentley\MICROS~1\examples>buildallexamples
[Fri 25/02/2022 12:31:28.97] [Fri 25/02/2022 12:31:28.97] PROCESSING STARTED[Fri 25/02/2022 12:31:28.98] [START] Building all SDK examples of type: .mke[Fri 25/02/2022 12:31:29.04] [COMMAND] bmake.exe +a C:\PROGRA~1\Bentley\MICROS~1\examples\ANNOTA~1\DESCRI~1\DESCRI~1.MKEBentley Systems Make Utility. Version 10.00.00.26, Mar 15 2018Fri Feb 25 12:31:29 2022
~mkdir Build\VSEnvironment\ PublicSDK\VsDevCmdImport.py --vsversion=2019 --targetarch=amd64 --targetframeworkversion=v4.6.2 --hostarch=x86 Build\VSEnvironment\VsDevCmd_16_v4.6.2_amd64.mkiThe system cannot find the path specified.Fri Feb 25 12:31:29 2022, elapsed time: 0:00BMAKE: call trace line: 1104, C:\PROGRA~1\Bentley\MICROS~1\mki\AssertToolSet.mki line: 114, C:\PROGRA~1\Bentley\MICROS~1\mki\ConfigurePolicy.mki line: 26, C:\PROGRA~1\Bentley\MICROS~1\mki\mdl.mki line: 17, C:\PROGRA~1\Bentley\MICROS~1\examples\ANNOTA~1\DESCRI~1\DESCRI~1.MKE[Fri 25/02/2022 12:31:29.20] [COMMAND] bmake.exe +a C:\PROGRA~1\Bentley\MICROS~1\examples\ANNOTA~1\DWGAPP~1\DWGAPP~1.MKEBentley Systems Make Utility. Version 10.00.00.26, Mar 15 2018Fri Feb 25 12:31:29 2022
BMAKE: call trace
Is it something to to with environment setting and not being able to find the right paths?
Lachlan Hand said:C:\Program Files\Microsoft Visual Studio\2022\Community
I don't think that Viz Studio 2022 is supported by the CONNECT Update 16 SDK (or earlier). Stick to a supported version (e.g. Viz Studio 2019).
Answer Verified By: Lachlan Hand
yep everything is working normally after installing VS 2019, thanks!
