There are a few examples of identifying EDF in a single textblock using the C++ api, i was hoping someone has done that in the .net api, or could point me in the right direction. I am able to Get Textblock, and create a caret, but how do I get a Run from a caret? Looks like there's Caret.MoveToNextRun, but that doesn't seem to return a run, and Caret.PreviousCharacter and Caret.NextCharacter returns just Char, which isn't going to help me identify if its an EDF or not. Is there another way of stepping through each part of a textblock?
Thanks.
Viktor_Kulik said:There are a few examples of identifying EDF in a single textblock using the C++ api, i was hoping someone has done that in the .net api
The TextBlock API in .NET is incomplete compared to the same API in C++. For example, using the C++ MicroStationAPI you can create a TextField, but that's not available in .NET.
I wrote a test code as below to get EDF from text element. It uses several new text related classes, such as ParagraphRange, ParagraphIterator and RunIterator.
private static void GetEDF() { ulong id = 1193; DgnModel dgnModel = Session.Instance.GetActiveDgnModel(); Element elem = dgnModel.FindElementById(new ElementId(ref id)); TextQuery txtQuery = TextQuery.GetAsTextQuery(elem); TextQueryOptions options = new TextQueryOptions(); TextPartIdCollection txtParts = txtQuery.GetTextPartIds(options); TextBlock txtBlk = txtQuery.GetTextPart(txtParts[0]); ParagraphRange paraRng = new ParagraphRange(txtBlk); ParagraphIterator paraIter = paraRng.GetParagraphIterator(); while (paraIter.MoveNext()) { RunIterator runIter = paraIter.GetRunIterator(); while (runIter.MoveNext()) { Run run = runIter.Current; EdfCharStream edf = run as EdfCharStream; bool isEdf = (edf == null) ? false : true; MessageCenter.Instance.ShowInfoMessage(run.ToString() + ", isEdf =" + isEdf.ToString(), null, false); } } }
My test text is as below:
Output in message center is as below:
I also just write a wiki to discuss what is TextPart as below. The article is in Chinese but I believe google can easily translate it into English.
关于TextBlock中的TextPart
That looks usable! Thanks Yongan.Fu , so a follow up question on this, using the ParagraphIterator and RunIterator should only be used for understanding the contents of the textblock but not for updating, right? If i need to update part of the EDF i would need to use the TextBlock.Insert.... methods? Is that right?
You are right for all your questions.
