loading object libraries / references dynamically
Hi all,
we're using some routines for excel output on different machines (using Excel Object Library.)
There we find different versions of excel and so different versions of object libraries:
How can we read the loaded references and load appropriate versions dynamically? (with GUID or so)
Any help appreciated,
cheers Ingo
  • How can we read the loaded references and load appropriate versions dynamically?
    That's a question for Microsoft, who invented COM without much forethought about your kind of problem.
    One approach is to eschew the COM libraries and use object creation by name...
    Dim oExcel As Object
    Set oExcel = CreateObject ("Excel")
    CreateObject looks for whatever COM class is registered with name Excel.  That should work on different computers with different versions of Excel.
    What you lose by that approach is interface binding — you no longer see hints about object properties and methods, and VBA can't check at compile time that you're calling the interface correctly.   Build your prototype using the Excel library reference, and for production create a version using CreateObject.
    Regards, Jon Summers
    LA Solutions
  • Hi guys,
    thanks for he replies,
    @Jan
    sorry I'm no coder - so I don't konw exactly what information you looking for.
    Maybe you can please help me what you need exactly.
    @Jon
    bit the same - I don't know where to start with your information.
    I was thinking of somthing like this what I found for Excel vba.
    Is this adaptable for Microstation?
    Public Sub prcShowReference()
        Dim objReferences As Object
        For Each objReferences In Workbooks("Test.xls").VBProject.References
            Debug.Print objReferences.FullPath, objReferences.Name, _
                objReferences.GUID, objReferences.Major, objReferences.Minor
        Next
    End Sub
  • Sorry I'm no coder — I don't know where to start with your information
    You can't solve your problem without someone experienced with VBA.  When in-house experience is not available, then hire a contractor. Jan is not too far away from Frankfurt.
    LA Solutions
  • okay - I've been coding in vba for some years but I was not taught in this field.
    So with some push in the right direction I think I can handle the task.
    But I'm not familiar with COM classes. So any further advice for that could help.
  • Hi ,
    I added two common Microsoft VBA code snippets on our VBEIDE page that we occasionally have to recommend to users in need of troubleshooting their Microsoft VBA projects.
    Feel free to try the VBEProjectReferences code snip to see if it helps provide the information needed.
    If or when you encounter any issues, please see our MVBATroubleshooting page for some common troubleshooting steps that may be required.
    Please note this is a MicroStation (not Microsoft) programming forum available to help users productively Search and Ask programming questions.
    Since your question is purely a Microsoft issue (not MicroStation specific) you may find more helpful Microsoft responses on Microsoft Forums; however this forum certainly helps users that have a desire to learn and create their own Microsoft and MicroStation custom code solutions in the process.
    HTH,
    Bob
  • I'm not familiar with COM classes
    VBA is COM.  Each class you create in VBA is a COM class and each UserForm is a COM class.  So you may not think you are familiar with COM, but you're using it all the time when you write VBA code.
    The key part of COM is that it defines an interface.  Other apps., whether VBA, C++ or .NET, can use that interface.  VBA can use an interface defined by some other app.
    This COM Server article shows how that is done.
    LA Solutions
  • Thanks Robert,
    that looks very promising and is the direction I was looking for.
    I'll dig into that.
    cheers,
    Ingo
  • for anyone who has similar questions: this is my result at the moment for switching to the correct ecxel vba support:
    two routines: one detaches, one attaches.
    thanks for all advice so far.
    'needs VBA reference
    ' Add: Tools > References: "Microsoft Visual Basic for Application Extensibility 5.3"
    Private Const stExcelGUID As String = "{00020813-0000-0000-C000-000000000046}"
    Option Explicit
    Public Sub VBAdetachXls()
        Dim oVBE                As VBE
        Dim oProject            As VBIDE.VBProject
        Dim oReferences         As VBIDE.References
        Dim oRef                As VBIDE.Reference
        Dim stMessage           As String
        Dim lgMinor            As Long
        Dim i                   As Integer
        Set oVBE = Application.VBE
        Set oReferences = oVBE.ActiveVBProject.References
        For Each oRef In oReferences
            If oRef.GUID = stExcelGUID Then
                lgMinor = oRef.Minor
                If lgMinor = 9 Then
                    oVBE.ActiveVBProject.References.Remove oRef
                    Debug.Print "detached vers. 9"
                    i = i + 1
                End If
                If lgMinor = 8 Then
                    Debug.Print "detached vers. 8"
                    i = i + 1
                End If
            End If
        Next
        If i = 0 Then
            stMessage = "nothing detached"
            Debug.Print stMessage
        End If
        'MsgBox stMessage
        Debug.Print "###"
    End Sub
    'try to attach latest xls
    'error if is attached
    Public Sub VBAattachXls9()
        On Error GoTo IsAttached
        Application.VBE.ActiveVBProject.References.AddFromGuid stExcelGUID, 1, 9
        On Error GoTo 0
        stMessage = "vba excel vers.9 attached"
        Debug.Print "###"
        'MsgBox stMessage
        Exit Sub
    IsAttached:
        stMessage = "ref is already attached or not found"
        Debug.Print "###"
        'MsgBox stMessage
        Exit Sub
    End Sub
Reply Children
