compile error trying to convert MDL to CONNECT
I installed VS2019, CONNECT and its SDK and I can compile the examples without a problem..
I am trying convert an MDL from SS3 to CONNECT. It is already in .DLL form and compiles within VS in SS3.
When the compiler gets to the type resource, I get this error:
[== Building D:\Users\KWA0GSU\AppData\Local\Temp\Bentley\MicroStationSDK\objects\fplcmd.rsc, (D:\fpl\devStudio\fplmdl\src\fplcmd.r) ==]
rcomp @D:\Users\KWA0GSU\AppData\Local\Temp\Bentley\MicroStationSDK\objects\make.opt
MicroStation Resource Compiler 10.16.01
BMAKE: no rules to build D:\Users\KWA0GSU\AppData\Local\Temp\Bentley\MicroStationSDK\objects\fpltyp.r
BMAKE: call trace
line: 69, D:\fpl\devStudio\fplmdl\src\fplmdl.mke
Mon Apr 04 15:30:20 2022, elapsed time: 0:00
My make file looks virtually identical to the myapp.mke example that compiles without error. Does anybody have any idea what could be going wrong here?
# Generate command table include & resource file using rcomp
$(o)fplcmd.h : $(baseDir)fplcmd.r
$(o)fplcmd.rsc : $(baseDir)fplcmd.r
# Create & compile the app's type resource using rsctype & rcomp
$(o)fpltyp.r : $(baseDir)$fpltyp.mt \
$(privateInc)fplids.h
$(o)fpltyp.rsc : $(o)fpltyp.r
# Set up to use dlmcomp.mki and dlmlink.mki
