[MSCE 10.16 c/c++] How to define camera plane
Hi ,
I'm writing an application that uses a camera that is modified (oriented) through user interaction, using mdlView_SetCameraParameters.
So far so good, but by default focal plane is always perpendicular to camera axis, and I need to orient it as required. Is there any way to orient focal plane as needed? In Microstation help it's shown as "One point projection", but I was not able to find anything in the Microstation API doc to achieve this.
Thanks in advance and best regards
