I use microstation 08.11.09.578, DGN 2D V7 Upgrade V8
I use C# language
I want to break the LineString association into separate LineStrings as shown below
ElementScanCriteria _MSesc = new ElementScanCriteriaClass(); _MSesc.ExcludeAllTypes(); _MSesc.IncludeType(MsdElementType.LineString); ElementEnumerator oEnumeration = app.ActiveModelReference.Scan(_MSesc); while (oEnumeration.MoveNext()) { oEnumeration.Current.AsLineElement().AsDroppableElement().Drop(); }
I tried but it gives error "Specified cast is not valid"
ba ranh said:I use microstation 08.11.09.578, DGN 2D V7 Upgrade V8
What do you mean by 'DGN 2D V7 Upgrade V8'?
MicroStation's native file format is a DGN file. A file contains DGN models. A model can be 2D or 3D. A DGN file is neither 2D nor 3D.
A previous version of MicroStation used a different file format that is referred to as V7. See the History of MicroStation.
Upgrade V8 is meaningless.
ba ranh said:I use C# language
When you write C# code for MicroStation V8i then you are calling the VBA COM interface. Prefer to develop your prototype using just VBA.
That way you...
ba ranh said:I want to break the LineString association into separate LineStrings
A VBA LineElement implements the VertexList interface. Get that list and create a new LineElement for each pair of vertices in that list.
LineElement
VertexList
Jon Summers said:A VBA LineElement implements the VertexList interface. Get that list and create a new LineElement for each pair of vertices in that list.
Good idea, thanks
It's not clear what you mean by "LineString association". The term "association" has exact meaning in MicroStation and API: Elements, like dimensions for example, can be associative to another elements. It does not make sense to use it in the discussed context.
ba ranh said:I want to break the LineString association into separate LineStrings as shown below
There are several issues in your code. I am not sure they are a result of not understanding how COM API works or you did not read API documentation carefully:
Another issue, but it's subjective one, is "an ugliness": You mixed old VB style (using names like oEnumeration does not make any sense today and is treated as bad practice generally) with C style (using _ for, probably, instance or local variables). When C# was released, naming best practices were defined by Microsoft, so when you decided to use C#, you also should follow the "C# code and naming style".
ba ranh said:into separate LineStrings
The solution recommended by Jon is the simplest and elegant one.
With regards,
Jan
Thank you for your useful sharing
ba ranh said:Good idea
Here's some sample code.
