I have a shared library (stand alone .dll file. No .ma file.) Is there any example of this in the CONNECT SDK?
Please be more specific for what functionality you are looking for, what version of MicroStation you are using, and what programming language.
Ken Adams said:I have a shared library (stand alone .dll file. No .ma file.)
A DLL is intended to be loaded into the address space of a running process. Presumably, that running process wants to access functions implemented in the DLL. One DLL can call functions in another. You can build a DLL using standard tools for Windows. Nothing to do with MicroStation.
When you build an app for MicroStation, the implementation is stored in a DLL. The above rules apply. The running process will be MicroStation. In addition to the DLL rules, MicroStation requires a resource (.ma) file usually of the same name as the DLL. The data contained in that .ma file tells MicroStation what to look for when you key-in mdl load KenAdamsApp.
.ma
Ken Adams said:Is there any example of this in the CONNECT SDK?
The SDK helps build an app for MicroStation. Why would you build a DLL that is unable to be loaded? One reason might be to have a DLL that stores code common to many of your apps, that each app's DLL can call. That common DLL might want to link with the SDK libraries to provide that common functionality, and it would never be loaded with key-in mdl load KensCommonDll.
If you don't need a .ma file, simply omit the part of your bmake file that generates that resource.
Hi Ken Adams,
As Mike requests, if you can provide some brief information related to your workflow or needs it may help provide better recommendations early on.
As Jon suggests, for MDL (.cpp Native Code) both a .DLL + .MA are required "to load" an application and access functionality defined in the .DLL library file - and - common Microsoft DLL library dependencies and common address space interactions are possible w/o need for Inter-Process Communication (a.k.a. IPC named pipes and queues preferred).
For MDL (.cs Managed Code) only a .DLL (standalone) file is generated as output; however behind the scenes the MicroStation .NET loader will create a temporary .MA image if not present "to load" a MDL .NET Addin application.
Bob
Sorry I was not more clear about my goal. I have a SS3 DLL I am trying to upgrade to CONNECT. It is a set of common functions that several other MDLs call. It has no .ma file itself.
I am simply trying to convert the make file at this point.
My SS3 make file looks a little different than my other make files. It has no cmd or typ resources or mki file. It is not as obvious how to use 'myapp' as a template to update this for CONNECT.
appName = fplcommon
MSJ_SKIP_SIGNRSCS = 0
DLM_NO_SIGN = 0
privateInc = $(baseDir)
%include mdl.mki
%if defined (_MakeFilePath) baseDir = $(_MakeFilePath)%else %if defined (powerc) || (m68k) baseDir = / %else baseDir = ./ %endif%endif
#---------------------------------------------# mdl.mki contains the default rules for creating .rsc, .mo, etc files#---------------------------------------------%if defined (MLINK_STDLIB) libraryExt = dlo%else libraryExt = ml%endif
# Display compile warning in MS/JmoreMdlCompileOpts + -b#------------------------------------------------# Set up to use dlmcomp.mki and dlmlink.mki#------------------------------------------------
DLM_OBJECT_DEST = $(o)DLM_LIBDEF_SRC = $(baseDir)DLM_NAME = fplcommonDLM_OBJECT_FILES = $(o)$(DLM_NAME)$(oext) DLM_LIBRARY_FILES = $(mdlLibs)dgnfileio.lib $(mdlLibs)toolsubs.libdlm_special_linkopt=-Fixed:no
#------------------------------------------------# Compile the source files for the DLM#------------------------------------------------%include dlmcomp.mki
$(o)$(DLM_NAME)$(oext): $(baseDir)$(DLM_NAME).c
#------------------------------------------------# Use dlmlink.mki to compile the Dynamic # Load Specification (.dls) file and link# the DLM.#------------------------------------------------
%include dlmlink.mki
#---------------------------------------------# Compile the Dynamic Link Specification#---------------------------------------------
$(o)fplcommon.dlo : $(baseDir)fplcommon.dls
$(mdlapps)$(appName).dll : $(mdlapps)$(appName).dll $(msg) -copy $(mdlapps)$(appName).dll ..\bin\$(appName).dll ~time
Ken Adams said:I was not more clear about my goal. I have a SS3 DLL I am trying to upgrade to CONNECT
OK, that's make sense!
Please insert your entire bmake file rather than a copy. There are a few things in there that are a hangover from MicroStation V7 days. There are some things in there that would not have built correctly in V8.
Hi Ken,
Jon wrote it already: Please attach the file (use Insert > Insert image/video/file tool). Or when you decide to share its content, use Insert > Insert code to ensure it will be readable and not displayed as plain not formatted text.
Ken Adams said:I am simply trying to convert the make file at this point.
In the first step, you should remove all macros that makes no sense:
Ken Adams said:It is not as obvious how to use 'myapp' as a template to update this for CONNECT.
My knowledge of using shared dll files in MicroStation native apps is limited, but I guess there is no big difference between "main dll" and "shared dll": When dll is to be loaded by MicroStation as "MicroStation application", there must be MdlMain method exported and .ma loader compiled, whereas shared .dll does not contain these definitions.
I recommend also to check dlmlink.mki for overview of DLM_ definitions, that can be used to configure different aspects of build process.
With regards,
Jan
Back around the 2000 BDN developer conferences Bentley made recommendations to 3rd party developers to Migrate Interpreted MDL code to Native code where that article provides the initial process and steps recommended in the migration chain you are likely need to exercise (now); being:
Migrating to CONNECT (parent topic and below list of migration actions needed between each major release)
HTH,Bob
appName = fplcommon MSJ_SKIP_SIGNRSCS = 0 DLM_NO_SIGN = 0 privateInc = $(baseDir) %include mdl.mki %if defined (_MakeFilePath) baseDir = $(_MakeFilePath) %else %if defined (powerc) || (m68k) baseDir = / %else baseDir = ./ %endif %endif #--------------------------------------------- # mdl.mki contains the default rules for creating .rsc, .mo, etc files #--------------------------------------------- %if defined (MLINK_STDLIB) libraryExt = dlo %else libraryExt = ml %endif # Display compile warning in MS/J moreMdlCompileOpts + -b #------------------------------------------------ # Set up to use dlmcomp.mki and dlmlink.mki #------------------------------------------------ DLM_OBJECT_DEST = $(o) DLM_LIBDEF_SRC = $(baseDir) DLM_NAME = fplcommon DLM_OBJECT_FILES = $(o)$(DLM_NAME)$(oext) DLM_LIBRARY_FILES = $(mdlLibs)dgnfileio.lib $(mdlLibs)toolsubs.lib dlm_special_linkopt=-Fixed:no #------------------------------------------------ # Compile the source files for the DLM #------------------------------------------------ %include dlmcomp.mki $(o)$(DLM_NAME)$(oext): $(baseDir)$(DLM_NAME).c #------------------------------------------------ # Use dlmlink.mki to compile the Dynamic # Load Specification (.dls) file and link # the DLM. #------------------------------------------------ %include dlmlink.mki #--------------------------------------------- # Compile the Dynamic Link Specification #--------------------------------------------- $(o)fplcommon.dlo : $(baseDir)fplcommon.dls $(mdlapps)$(appName).dll : $(mdlapps)$(appName).dll $(msg) -copy $(mdlapps)$(appName).dll ..\bin\$(appName).dll ~time
I confess my knowledge of the intracacies of how make files work is limited. But this attached file does work in producing a usable DLL for my other V8 SS3 applications with no apparent errors.
Bentley Systems Make Utility. Version 08.11.09.02, Jan 5 2010 Wed Apr 13 16:22:40 2022 PolicyFile = D:\mdl\MicroStation\mdl\include\AssertPublicMicroStationPolicy.mki [== Building D:\mdl\MicroStation\mdl\objects\fplcommon.obj, (D:\mdl\fpl\devStudio\fplcommon\src\fplcommon.c) ==] cl -Dtarget_is_dlm -ID:\mdl\MicroStation\mdl\include -ID:\mdl\MicroStation\mdl\include\geom -ID:\mdl\MicroStation\mdl\include\shareids -GS- -fp:fast -EHc -GR -GdF -D_X86_=1 -Di386=1 -c -W3 -DWIN32 -DwinNT -MD -D_VISCXX -Gy -wd4996 -Ox -Oy- -Os -D_SECURE_SCL_THROWS=1 -D_CONVERSION_DONT_USE_THREAD_LOCALE -D_SECURE_SCL=0 -DWIN32_LEAN_AND_MEAN -nologo -WX -Zi -FdD:\mdl\MicroStation\mdl\objects\objects.pdb -EHs -arch:SSE2 -FoD:\mdl\MicroStation\mdl\objects\fplcommon.obj D:\mdl\fpl\devStudio\fplcommon\src\fplcommon.c fplcommon.c [== Building D:\mdl\MicroStation\mdl\objects\fplcommon.dlo, (D:\mdl\fpl\devStudio\fplcommon\src\fplcommon.dls) ==] D:\mdl\MicroStation\mdl\bin\dlmspec @D:\mdl\MicroStation\mdl\objects\temp.cmd MicroStation Dynamic Load Specification Compiler 08.11.09 [== Building D:\mdl\MicroStation\mdl\objects\dllentry.obj, (D:\mdl\MicroStation\mdl\library\dllentry.c) ==] cl -Dtarget_is_dlm -ID:\mdl\MicroStation\mdl\include -ID:\mdl\MicroStation\mdl\include\geom -ID:\mdl\MicroStation\mdl\include\shareids -GS- -fp:fast -EHc -GR -GdF -D_X86_=1 -Di386=1 -c -W3 -DWIN32 -DwinNT -MD -D_VISCXX -Gy -wd4996 -Ox -Oy- -Os -D_SECURE_SCL_THROWS=1 -D_CONVERSION_DONT_USE_THREAD_LOCALE -D_SECURE_SCL=0 -DWIN32_LEAN_AND_MEAN -nologo -WX -Zi -FdD:\mdl\MicroStation\mdl\objects\objects.pdb -EHs -arch:SSE2 -FoD:\mdl\MicroStation\mdl\objects\dllentry.obj -GS- D:\mdl\MicroStation\mdl\library\dllentry.c dllentry.c [== Building D:\mdl\MicroStation\mdl\objects\fplcommon.lib, (D:\mdl\MicroStation\mdl\objects\fplcommon.def) ==] lib @D:\mdl\MicroStation\mdl\objects\fplcommonlib.rsp Microsoft (R) Library Manager Version 8.00.50727.762 Copyright (C) Microsoft Corporation. All rights reserved. -out:D:\mdl\MicroStation\mdl\objects\fplcommon.lib -def:D:\mdl\MicroStation\mdl\objects\fplcommon.def -machine:X86 Creating library D:\mdl\MicroStation\mdl\objects\fplcommon.lib and object D:\mdl\MicroStation\mdl\objects\fplcommon.exp [== Building "C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll", (D:\mdl\MicroStation\mdl\objects\fplcommon.obj) ==] link -out:"C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll" -WX -OPT:NoWin98 -Ignore:4087 -Ignore:4089 -Release -debug -incremental:no -fixed:no @D:\mdl\MicroStation\mdl\objects\fplcommonlink.rsp Microsoft (R) Incremental Linker Version 8.00.50727.762 Copyright (C) Microsoft Corporation. All rights reserved. -dll "-out:C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll" "-implib:D:\mdl\MicroStation\mdl\objects\fplcommon.lib" -entry:LibMain@12 -map:D:\mdl\MicroStation\mdl\objects\fplcommon.map "-pdb:C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.pdb" -Fixed:no -MANIFESTFILE:D:\mdl\MicroStation\mdl\objects\fplcommon.dll.Manifest D:\mdl\MicroStation\mdl\objects\fplcommon.obj D:\mdl\MicroStation\mdl\library\dgnfileio.lib D:\mdl\MicroStation\mdl\library\toolsubs.lib D:\mdl\MicroStation\mdl\objects\dllentry.obj D:\mdl\MicroStation\mdl\objects\fplcommon.exp D:\mdl\MicroStation\mdl\library\mdlbltin.lib C:\PROGRA~2\MI30EB~1\VC\platformsdk\lib\gdi32.lib C:\PROGRA~2\MI30EB~1\VC\platformsdk\lib\user32.lib C:\PROGRA~2\MI30EB~1\VC\platformsdk\lib\kernel32.lib C:\PROGRA~2\MI30EB~1\VC\lib\msvcrt.lib mt.exe -manifest D:\mdl\MicroStation\mdl\objects\fplcommon.dll.Manifest -outputresource:"C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll";2 Microsoft (R) Manifest Tool version 5.2.3790.2075 Copyright (c) Microsoft Corporation 2005. All rights reserved. [== Building D:\mdl\MicroStation\mdl\objects\fplcommon.dlo, (D:\mdl\fpl\devStudio\fplcommon\src\fplcommon.dls) ==] D:\mdl\MicroStation\mdl\bin\dlmspec @D:\mdl\MicroStation\mdl\objects\make.opt MicroStation Dynamic Load Specification Compiler 08.11.09 [== Building C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll, (C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll) ==] copy C:\PROGRA~2\Bentley\MICROS~1\MICROS~1\mdlapps\fplcommon.dll ..\bin\fplcommon.dll 1 file(s) copied. Wed Apr 13 16:22:43 2022, elapsed time: 0:03
Ken Adams said:my knowledge of the intracacies of how make files work is limited
I know how you feel.
Here's an updated version of your bmake file. Keep in mind that I can't test it because I have none of your source code. It's a shot in the dark...
KenAdams.zip
