[CE][C#] Select specific Element from a Parametric Solid
Hi folks,
I want to specifically select an Element of a Parametric Solid.
As example I have this Parametric Solid:
Now I want the Element behind "Profile #1" that was used for the Extrusion. I have no problems to get all 5 Profiles but I have no Information which Element belongs to which feature. I also have no issues to find the list of all features but I can't make the connection. From a feature and from an Element, I only find back to the root Element.
In the list of all Profiles, its the first Element but only when I didn't replaced it. I've looked at the EC Objects Values but didn't saw any connection between the features and the actual Elements.
Thanks in advance.
