I am trying to convert a macro written in BASIC language to VBA to run in Connect version. Below is the code i want to convert into MVBA.
point.x = 1 point.y = 1 point.Z = 0 MbeSendDataPoint point, 1
Also MbeSendCommand "PLACE SMARTLINE " .
Hi Bipin Thapaliya,
If you have many similar Scripts and Macros try to Record a Macro in the CONNECT Edition product to first attempt to find similar (and simple) functional script/code substitutions.
Then as Jan recommends make sure to get familiar with the MicroStation VBA Help (MicroStationVBA.chm) and MicroStation VBA Object Model to find your VBA programmatic options vs. (recorded) scripts. Also you may want to look our Training > MicroStation VBA Getting Started topics that may also help.
HTH,Bob
Thank you .
