Hi, how to convert coordinates between gcs in mdl with some command or function?For example, the dgn file contains WGS coordinates and I want to convert the data to another GCS by reprojecting?
If you are using C++ on MSCE, please refer to the DgnGCS::ReprojectUors functions.
