Im trying to create a shape (rectangle). I'm following this page MicroStation .NET: Create Shape using C# (la-solutions.co.uk)
but when i get to the step of casting the CurveVector to a DgnCurveVector I get an Exception "Unable to cast object of type 'Bentley.GeometryNET.CurveVector' to type 'Bentley.GeometryNET.DgnCurveVector'"
i tried just using the the CurveVector to create the element but it creates it as a line string instead of a shape. CurveVector does not have the SetBoundaryType method so it looks like if I want a shape then I need to use DgnCurveVector. The main different from the example in the link above is that the example is doing this by collection datapoints from a DgnPrimitiveTool where I'm just specifying the points via code.
Not really sure where I went wrong.
DPoint3d[] pnts = new DPoint3d[5]; pnts[0].X = 0; pnts[0].Y = 0; pnts[1].X = 2; pnts[1].Y = 0; pnts[2].X = 2; pnts[2].Y = 3; pnts[3].X = 0; pnts[3].Y = 3; pnts[4].X = 0; pnts[4].Y = 0; GPArray gPArray = new GPArray(); gPArray.Add(pnts); DgnCurveVector curves = (DgnCurveVector)gPArray.ToCurveVector();
any ideas?
