[CONNECT Update 17 C++] MDL load error in MicroStation Update 17
Hi!
I have a native MDL application that runs perfectly in MicroStation Update 16, but in MicroStation Update 17 I get a MDL loader error 127
I'm using the latest MicroStation SDK when compiling the application.
I have other native MDL application running fine on Update 17
The application failing is using the library ECObjects.lib to handle ItemTypes
If I comment out the parts of the application using routines and structures from ECObjects.lib, the application loads without errors, so I expect that it has something to do with loading ECObjects6.dll
Can anyone tell me how to solve this problem of tell me what error 127 means
Best regards
Jesper Stahl Madsen
WSP Informatik
