I need to take all the attached reference files and add them into a batch process. I can iterate the reference files but I'm stuck on how to create / add to a batch process. Is that possible with VBA code, and if anyone has a code snippet they can share?
V 10.16.00.80
Hi Michael,
There are at least two ways of doing a "batch" process. One would be to use Microstation's built-in batch process, and another would be to use VBA to open the files and do the work itself.
If you have a list files in an array FileFullPathNames(), you could do something like
For I = Lbound(FullPathNames) to Ubound(FullPathNames) OpenDesignFile FileFullPathNames(I) [do something to the file] Next
--Robert
