How to I get this selection chosen by vba or key-in command
"Enable to create relative associations to elements"
Recording the macro makes changes to the association lock only
I need "relative associations to elements" or is there a way to
manipulate the dialog window somehow. I am creating a macro
that places to cells. One of them is an cell describing an instrument with item attached
Other is label pointing to that cell. It works only if
"Enable to create relative associations to elements" is chosen
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
Petri Haikola said:How to I get this selection chosen by vba or key-in command
One approach is to record a VBA macro. Sometimes the recording reveals details of the application variable that is modified when you click in the user interface.
I am using the latest Microsoft CONNECT edition update 17 Version 10.17.01.62
Recording the macro does not help in this situation. Recording the macro either does not give anything or it will give something like tcb->assocLockMask, 16. This will manipulate the association lock it does not manipulate the "Enable to create relative associations to elements".
It would by helpful if I could set this on from preferences or what not. Every time the dgn-fie is reopened Microstation will forget this setting and set it off. The setting once set manually will stay open for the duration of a single use only even if settings are saved.
Hi Petri,
Petri Haikola said:Recording the macro either does not give anything
Unfortunately it looks like the tool does not follow MicroStation best practices (better to say developers does not implemented it right): Whenever possible, all tool parameters should be accessed by "set item toolsettings" key-in, but it does not work with the discussed tool. And also the tool probably does not publish all internals, so the recorder is not able to monitor them.
Petri Haikola said:or it will give something like tcb->assocLockMask
assocLockMask is opaque 16bit mask with no further details available, so the only thing that is clear is that 5th bit controls "Enable to create relative associations to elements" switch.
What bit (and if) controls the 2nd switch is not described and unfortunately it seems macro recorder is not able to monitor such task right. It's possible (using C-expression) try all bit in the mask, but it's a bit time consuming and risky.
Petri Haikola said:It would by helpful if I could set this on from preferences or what not.
It is solely the responsibility of the tool itself, MicroStation itself does not control/manage whether tools store their settings. So if you would like to enhance this tool in this way, I recommend to create a new idea in MicroStation community.
With regards,
Jan
Hi Petri Haikola ,
As Jan Šlegr mentions unfortunately the Place Label Tool Settings are not able to be recorded and filing an MicroStation (product) Idea is a good idea.
Though Place Label does not record well for playback at this time; the Place Label tool does provide all the (placelabel) key-ins needed to accomplish what you need; where you could send key-ins (even all on one line separated by ";") similar to this:
e.g.
HTH,Bob
Answer Verified By: Petri Haikola
Thank you Robert and Jan,
I just tested it and your solution does work
Like you suggested I Added these lines to my macro
CadInputQueue.SendKeyin "placelabel associationstate on" CadInputQueue.SendKeyin "placelabel relativeassociationstate on"
And was able to turn the "relative associations to elements" button on.
