When I was coding with the Microstation VBA Text Editor, it suddenly crashed when typing the call of Function (in the same mvba). It crashed mainly when I incorrectly typed "," or ".". However, it cannot be reproduced when I was forced to restart the Microstation. Just a sudden crash, I did not click compile / run macro / save button.
Anyone experienced that kind of problem? And how to avoid it?
Hi clever_anthony ,
Although there may be other possibilities, my first suspicions are to consider:
If possible, see if you can locate any MicroStation Crash Dump files on your system (.dmp and/or .hdmp) very close in approximation to the time you noticed the exception.
To locate the .dmp/.hdmp files you can try:
If you find any, you can Zip and send them using our Secure Upload option.
HTH,Bob
Could you please help check if the Dump files were uploaded? I uploaded it without any login.
Being anonymous uploads to ensure a quick and accurate review, can you...
Thank you in advance,Bob
I am not sure if that file was uploaded because I could not see any "submit" bottom after upload success.
Robert Hook said:Let me know the exact File Name(s) uploaded?
The file name should be exception.zip (one zip file)
Robert Hook said:Let me know the Date and Time of "the event(s)"?
The zip file contains two different date, which should be on 2022-11-28 and 2022-12-07. The crash case should be the same - VBA Text Editor crashed, cannot input text after exception.
On the other hand, may I have any Bentley validation tool to check if the MVBA file is not corrupted? (although it looks fine now)
Thank you. I will take a look at the exceptions in the file noted soon.
As for VBA Validation Tool, in the past we created an internal MicroStation VBA macro that used the VBE (project) APIs by referencing: Microsoft Visual Basic for Applications Extensibility 5.3 (VBE6EXT.OLB). It simplified (rarely needed) manual steps for a given selected project to:
Since the steps above can be done manually and not needed all that often a couple steps I suggest in addition would include:
The reason the Export/Import steps may be required is because Microsoft component meta associated to Project Files and References can get out of sync and cause things to behave inconsistently (though have not seen any crashes related to such issues) and Export/Import can often fix hard to find inconsistency issues.
The reason to perform the Additional Steps are simply very good Microsoft/MicroStation VBA best practices to perform sanity checks to help ensure consistent and reliable operation.
I still need to find some time to review the dump file provided, however when reviewing the exception.log and with respect to my concern above (#2 - Location of .mvba Files), can you (or the user) consider:
Exception.log shows "U://" convention being used to locate MicroStation VBA macros:
MS_VBASEARCHDIRECTORIES: WorkSet = U://;D:\LPM2\Microstation for LPM2\CE\
Robert Hook said:Moving any MicroStation VBA macros locally
The VBA marcro was in D:\
There were no mvba files in U://. (I installed Microstation by myself and I don't know why they are pointed to U://, it looks like a group policy of the Government). U is a network mapped drive and D drive is a local disk. I don't think any network drive would be involved. In particularlly, I always load only one MVBA file to edit, because I would not know what would the behavior to be when you click "Save" Button.
Robert Hook said:Setting the MicroStation Configuration Variable MS_VBA_OPEN_IN_MEMORY=ALL
That is an interesting suggestion. I will update you the information if I meet the crash again.
If you enable this Configuration Variable, you cannot "Save" the code after editing. If you close the Microstation, it will ask you to save as a new MVBA file. However, the size of new file is 38% of original size. Should I use replace "ALL" by "READONLY"?
clever_anthony said:Should I use replace "ALL" by "READONLY"?
Depends if (at the time) you need to be acting as a User (Value set to ALL multi-share in production) or as a Developer (Value set to READONLY needing to update R/W the original .mvba file).
