HI Team,
I am replacing the text using Excel Macro. If i load the excel macro (mvba) on V8, its working fine.
if i execute it directly from Excel File(VBA) (note i have MicroStationDGN.OpenDesignFile myFileName) , Application is finding the matches, but its not replacing it. I am getting "Error No -2147221504 is locked caused by vba project"
Please advice.
Thanks!
Ramakrishnan Sivasubramanian said:i have MicroStationDGN.OpenDesignFile myFileName
Please show your exact VBA code!
Ramakrishnan Sivasubramanian said:note i have MicroStationDGN.OpenDesignFile myFileName
as Jon wrote, share your code. It's the thing where all developers' discussion start.
Also, please follow this forum best practices and use standard subject format to share information about used product and its version. It makes communication simpler.
Ramakrishnan Sivasubramanian said:I am getting "Error No -2147221504 is locked caused by vba project"
Are you aware of differences when MicroStation application object is used (called) from another application (process)? In such situation specific requirements must be fulfilled. I recommend to check MicroStation VBA documentation, especially a description of ApplicationObjectConnector Object and related code snippets.
With regards,
Jan
