Would it be possible to populate the Explorer Details dialog using VBA?
I would like to scan the file (or select) for elements and just display the attached Item Type information in the details dialog.
/Krister
Hi Krister,
I think it is not possible: You can open Details dialog using dialog details open key-in, but it displays Explorer current selection details, not specifically Items details.
dialog details open
And I did not find any key-in to change Explorer display mode to Items tab, when Details dialog displays the attached data.
With regards,
Jan
We do something like this but have to use our own form to display the desired Item Type information we want to see (not use the Explorer panel)
