I have a follow-up question. In general, can we modify built in commands using VBA? I would like 2 separate commands:
1. Drawing a line at a slope.
2. Annotate/Measure the slope of a line.
Both commands are almost available in Microstation and I just need a slight change.
1. Instead of defining angle for command place line. I want to define slope (1:x) or percentage (5%).
So I hope, that there is an option to make simple macro that modifies the command place a line at angle as follows. Macro opens a form similar to that below where user define his input and based on format a function in the macro calculates the angel that is send to build in command place a line at angle. The user would picked 2 points while accudraw and snap modes available and it's done.
2. Instead of labeling line with angle (element dimensioning -> label line). I want to label it with 1:x or 5%.
In this case we just need to multiply the value by right number (calculated in macro) and add prefix or suffix. It would remain associative.
Are both cases possible for ordinary users or it is somehow protected and only bentley's developers can do this slight changes?
I appologize if my question is too silly because I am a total VBA and Microstation beginer.
Tom
(+) Measure the slope of a line? - MicroStation Forum - MicroStation - Bentley Communities
Look at the link above, wrote a VBA Tool back in 2003. Couple of users modified it, but any one of them will get you a great start
LARRY WILSON | Senior Designer Crawford, Murphy & Tilly | Engineers & Consultants 84 Remick Blvd. | Springboro, OH 45066 lwilson@cmtengr.com
