I'm trying to automate a task for a colleague. I use VBA in other applications but do not use MicroStation so I may be going about this the wrong way.
I have a number of DGN files in a folder. I'm trying to loop through each file to save as .dwg and rename file to include this file type. This happens once a quarter and is done manually at present.
I recorded a macro while saving a .dgn file to .dwg and tried to modify this. However, I'm not able to create the new files. The original macro option worked for a single file but not while looping through the files.
Full code below. Note, for testing, once I open MicroStation, I open the Macro under Utilities tab and click edit icon to open VBA. From there I I'm simply running the module BmrMacroExportTest() below.
Question: Is VBA the option to batch save files to different formats? If so, can someone point out the error in my code? If I can get this to work, I will also output to .dxf and give user input option to select folder location as it updates per quarter.
Thanks in advance for any assistance.
Module: modMacroExportTest Sub BmrMacroExportTest() Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d Dim lngTemp As Long Dim oMessage As CadInputMessage Dim modalHandler As New BmrMacroExportTestModalHandler AddModalDialogEventsHandler modalHandler ' The following statement opens modal dialog "Save As" ' Send a keyin that can be a command string CadInputQueue.SendKeyin "DIALOG SAVEAS " RemoveModalDialogEventsHandler modalHandler CommandState.StartDefaultCommand End Sub Class Module: bmrMacroExportTestModalHandler Implements IModalDialogEvents Private Sub IModalDialogEvents_OnDialogClosed(ByVal DialogBoxName As String, ByVal DialogResult As MsdDialogBoxResult) End Sub Private Sub IModalDialogEvents_OnDialogOpened(ByVal DialogBoxName As String, DialogResult As MsdDialogBoxResult) Dim strInputPath As String Dim strInputFile As String Dim strOutputFile As String Dim strOutputFormat As String Dim blnContinue As Boolean strInputPath = "DRIVE:\...\FINALFOLDER\" ' Loop through input files in input path strInputFile = Dir(strInputPath & "*.dgn") Do While strInputFile <> "" ' Set output file name and format strOutputFile = Left(strInputFile, Len(strInputFile) - 4) strOutputFile = Replace(strOutputFile, "DGN8", "DWG") ' Export to DWG strOutputFormat = "DWG" If DialogBoxName = "Save As" Then Call SaveNewFile(strInputPath, strOutputFile & "." & LCase(strOutputFormat)) End If ' ' Move to next input file strInputFile = Dir() Loop End Sub Private Sub SaveNewFile(strPath As String, strNewFile As String) CadInputQueue.SendKeyin "MDL COMMAND MGDSHOOK,fileList_setDirectoryCmd " & strPath CadInputQueue.SendKeyin "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd " & strNewFile ' Remove the following line to let the user close the dialog box. DialogResult = msdDialogBoxResultOK End Sub
Donal O Caoimh said:Is VBA the option to batch save files to different formats?
See the SaveAs method in VBA Help: Saves the current file under a different file name and, optionally, in a different file format.
Enum MsdDesignFileFormat includes msdDesignFileFormatDWG. VBA help is delivered with MicroStation: here's how to find it.
Hi Jon,
Many thanks for that. The location of this help was not apparent! I tried the SaveAs option briefly but I don't think it's the best approach.
I have since found the Tools - Batch Converter route which does what it says on the tin. This is being tested at the moment so if that works, I won't need to proceed with the VBA option. As a newbie in MicroStation VBA, it does look a bit cumbersome and more difficult to get started with than VBA elsewhere. Presumably this has a lot to do with my lack of knowledge in MicroStation itself.
Donal
Batch Converter really is the better tool for the job, IMO. No need to recreate a tool that already works.
VBA for MicroStation isn't bad - it's just pretty MicroStation specific. If you aren't familiar with the software, and how it works in daily use, I can imagine that it would be difficult to wrap your head around what a program might need to work. I use Excel, but I'm not very proficient, and I find Excel VBA challenging.
What I like about the MicroStation VBA help is that it includes many code snips to illustrate how various tools, properties and methods function. That was very helpful to me when I was learning to code.
MaryB
