I have one file that is causing issues for all users and receiving the below errors.
We are running PowerGeopak SS10 08.11.09.918 for this particular project.
Hi Brandi Morgan ,
Try to run the program using the: Icon > Right Click > "Run as Administrator" option. You may need to do this once after a program was updated or the first time a new user tries to run the program the first time. After running once as Administrator, you should be able to run the program as a standard user.
If that does not work, then you may need to try some specific/common attempts to repair your installation, like:
HTH,Bob
