Hello,my VBA does not seem to read the variables on the xy= command/ key-in. So xy=100,200 works ok but xy=(var1),(var2) does not work. the VBA reads value zero by default. I have a msgbox (var1), so the values are really filled in. There is no syntax error either.Thank you very much for any clueNico
Many thanks Jan,
sorry for the lack of info.
It is fixed now. Bentley Support, Arthur Goldsweer helped me out.
2023-06-23 01:29:46 PDT - Artur Goldsweer Additional comments
Hello Nicolas,
from your problem description it is not clear what the problem in detail is. In general there are no issue with using variables with keyin commands.
I just mad a quick test with VBA and using x,y values as double and this example works fine:
Sub xytest() Dim x As Double Dim y As Double x = 2.12345 y = 3.23456 Dim sCmd As String sCmd = "xy=" & CStr(x) & "," & CStr(y) CadInputQueue.SendKeyin "place line" CadInputQueue.SendDataPoint Point3dZero CadInputQueue.SendKeyin sCmd CadInputQueue.SendReset End Sub
If this code example does not help to fix the issue, please provide a code example to allow us to reproduce the issue - thanks
Best regards,
Artur Goldsweer BDN Technical Support
I had
Dim point_X0 As Double Dim point_Y0 As Double
point_X0 = 0 - L point_Y0 = 0CadInputQueue.SendCommand "Place Line;xy=0,0;xy=(point_X0),(point_Y0);reset"
Sorry again, I am an occasional VBA clumsy user.
Nico
The issue here is that you need to assemble the command string (sCmd) out of your variables.That is what
sCMD = "xy=" & CStr(x) & "," & CStr(y) does.
"xy=" and "," are text. Cstr(x) and CStr(y) convert the double values to strings for use in the command, and & is the symbol to concatenate the entire line into a single string. That string is then used to the keyin sent to MicroStation.
You have example code right in front of you, but you have strayed significantly from it. Rewrite your code to follow the steps as shown in the example. Learn what each step does. Once you understand how the code works, you can adjust it if you like, but if you don't understand what your example is doing, your success at rewriting it is going to be nil.
Dim Point_X0 as Double Dim Point_Y0 as Double ' define coordinates Point_X0 = 1234 Point_Y0 = 5678 'create command string Dim sCmd as String sCmd = "xy=" & CStr(Point_X0) & "," CStr(Point_Y0) 'Start the Place Line command CadInputQueue.SendKyin "place line" 'place the first data point at zero CadInputQueue.SendDataPoint Point3DZero ' send the previously defined command string CadInputQueue.SendKeyin sCmd 'reset to end the line CadInputQueue.SendReset
There are other things amiss in your code. I have no idea what "L" is or where that is defined, so that's an obvious problem as well.
MaryB
