Instruction to build an Add-in from SDK cannot be followed.
Hi Everybody,
I tried to following the online instruction (of the following link) to build a simple add-in using Visual Studio, but cannot it seems cannot be followed. Can you advice whether there is updated document? or whether I have made any mistake?
communities.bentley.com/.../building-a-simple-add-in-application
I am trying in a Windows 11 system, I have these software packages installed: Microstation 2023, Microstation CONNECT 10.17.2.6.1, Microstation CONNECT Edition SDK 10.17.02.009, Visual Studio Enterprise 2017/2019/2022.
I first tried Visual Studio 2017. When following step 1 of the aforementioned page, after selecting File> New> Project, I couldn't find any Bentley/Microstation related options from the left hand side of the popup window (Screenshot added below). Hence, I couldn't follow the instruction to select Bentley > MicroStation > Connect Edition > MDL Command.
I then tried Visual Studio 2019 and 2022. In these newer versions of Visual Studio, the Create a New Project popup windows do not have the left panel for user to select C# on left hand side as instructed. I attempted to search for templates related to Bentley or Microstation, but still found nothing.
Can you help to check whether the aforementioned document has newer version somewhere for newer Microstation SDK package? or whether I have made any mistake when following it?
Thank you!
