VBA script to detach display off borders from MicroStation connect edition ?
please respect the best practices and using standardized subject format, provide common required information about the used product, its version and used API. It makes the communication more efficient and the subject typically also more concise.
Nayeem Ahmed said:VBA script to detach display off borders from MicroStation connect edition ?
What is your question? Are you asking anybody to write such script?
Nayeem Ahmed said:to detach display off borders
Do you want to switch the display off, so the reference is not displayed, but still attached, or you want to detach it?
Mixing both in one question makes your intention not clear.
Nayeem Ahmed said:borders from MicroStation
What borders? How they can be identified? What is context of this action (e.g. is it run in batch mode, using key-in...)?
Is VBA necessary? Cannot be MicroStation key-in used to detach specific reference?
Jan
