I am using MicroStation CONNECT version 10.16.03.11.
Through the normal Place Text dialog, there is the ability to place the text element with a relative association to another element (e.g., a line element).
In looking at the Attributes of the text element, I notice this...
Next, when placing a dimension element with these settings to label the length of a line...
I then notice these properties via the Attributes tab for the dimension element...
What type of association or dependency corresponds to this "Projection" version? For example, is it perhaps the mdlAssoc_createLinear function?
Please refer to the new C++ function AssociativePoint::InitProjection(...).
Answer Verified By: Matthew Ashby
