We have an MDL app that scales text/cell elements. We noticed that if the scale of the element was anything other 1, the ILocateCommandEvents will no longer be able to select those elements. Here's the code that we're using to scale elements. Are we doing anything wrong to make the element unselectable?
static void scale_element(const long attr_mode, MSElementDescrP *descrip, MSElementDescrCP original, const double factor) { if ((attr_mode & ATTRIBUTE_SCALE) != ATTRIBUTE_SCALE) { return; } Dpoint3d origin; TextBlockPtr textBlock; switch (mdlElement_getType(&original->el)) { case DgnPlatform::CELL_HEADER_ELM: mdlCell_extract(&origin, NULL, NULL, NULL, NULL, 0, &original->el); break; case DgnPlatform::TEXT_ELM: case DgnPlatform::TEXT_NODE_ELM: textBlock = TextHandlerBase::GetFirstTextPartValue(ElementHandle(original, false)); origin = textBlock->GetUserOrigin(); break; //mdlTextNode_extract(&origin, NULL, NULL, NULL, NULL, NULL, &original->el, original); //break; //Potential future enhancements case DgnPlatform::LINE_ELM: case DgnPlatform::LINE_STRING_ELM: case DgnPlatform::SHAPE_ELM: //mdlLinear_extract(&origin, NULL, &(element->el), modelRef); return; case DgnPlatform::ELLIPSE_ELM: //mdlArc_extract(&origin, NULL, NULL, NULL, NULL, NULL, NULL, &(element->el)); return; case DgnPlatform::DIMENSION_ELM: return; case DgnPlatform::CMPLX_STRING_ELM: return; case DgnPlatform::CMPLX_SHAPE_ELM: return; default: return; } Transform transform; mdlTMatrix_getIdentity(&transform); mdlTMatrix_scale(&transform, &transform, factor, factor, factor); mdlTMatrix_setOrigin(&transform, &origin); mdlElmdscr_transformAllowModification(descrip, &transform, MASTERFILE, MASTERFILE, DgnPlatform::TRANSFORM_OPTIONS_ModelFromElmdscr); }
Thank you,
Kevin
Just to add a bit more information. From the scale_element function, we're scaling both cells and text/textnodes. We are able to select cells after the scaling but text/textnodes are not selectable.
