I have installed Visual Studio 2003 ,2005 and the MicroStation V8i (SELECTseries 1) SDK for Microstation V8i. Can anyone suggest to install addin wizard for vs2005?
If you can get a hold of the MicroStationSDK Select Series 3 build we put the Wizards and there instructions in the installation. The instructions are in the Programers Guide. Essentially you need to copy the .vsz, .vsdir, and .ico files to the Visual Studio VC\VCProjects directory. You then need to edit the .vsz file to point to where you are going to keep the wizard files. Once that is done start Visual Studio and you should see them appear in the VC++ collection of wizards.
HTH,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Thanks for your reply.
How can i create a mdl project (c++) using wizard. Is there any sample solution or link to create a solution ?
kalaiarasi said:How can i create a mdl project using wizard?
After creating a project using addin wizard I got below error
fatal error C1107: could not find assembly 'Bentley.General.1.0.dll': please specify the assembly search path using /AI or by setting the LIBPATH environment variable
After I set the assembly search path I am getting below errors,
1>.\MicroStationAddInWizard1.cpp(38) :error C2059: syntax error : 'public'1>.\MicroStationAddInWizard1.cpp(38) : error C2059: syntax error : 'public'1>.\MicroStationAddInWizard1.cpp(39) : error C2143: syntax error : missing ';' before '{'1>.\MicroStationAddInWizard1.cpp(39) : error C2447: '{' : missing function header (old-style formal list?)1>.\MicroStationAddInWizard1.cpp(83) : error C2059: syntax error : '}'1>.\MicroStationAddInWizard1.cpp(83) : error C2143: syntax error : missing ';' before '}'1>.\MicroStationAddInWizard1.cpp(83) : error C2059: syntax error : '}'
