In Microstation V8i the view has an option to enable scrollbars on view windows. It can be found under Workspace/Preferences/View Options.
My question is how can I turn it on from code or with a configuration variable? I'm using mdl with cpp.
One way would be to set userPrefsP->extFlags.borderlessViews from within a MicroStation session -- 0 for scroll bars, 1 for no scroll bars. Note that when you do that, you will have to close and reopen the view windows to see the change.
Thanks, it works.
Unknown said: Thanks, it works.
As expected, but do you really want to restrict users that way ?!
I would pull you through the telefon line if your app would do this to my user settings ;-)
Maybe you have to fullfill company internal standards, but still very restrictive (imho).
