Hallo,
Sometimes I have the problem that controls (especially ListViews) are displed incomplete (see attatched screenshots). When moving other forms over that incomplete form, it is drawn/displayed correctly. A Listview.refresh does not help to draw the control correctly.
Does anyone know about that problem or even knows a solution for fixing it?
Gottfried
sorry I forgot to attatch the screen-shots - here they are:
This is an Addapter issue... The only way I have found to solve this is to add a Timer with interval 500 to the form and refresh it in tick method...
Thank you, DanPaul!
Your suggestion works fine!
