(VBA - V8i) Set Dimension Offset
I am trying to create dimensions programatically using MicroStation VBA.  I can create the dimensions and vary the properties, but I cannot make the witness line move from the edge of the square it is dimensioning.  I have tried seemingly everything combination of dimension properties that I can think of.  Obviously there is one more (the correct one) that I have not found yet.
Here are the results I am getting at the moment.  There have been many other variations on the extension line, but the witness line stubbornly refuses to move at all.
Here is a snippet of the code as it stands at this moment.  I just drew the box using a shape connecting the vertices in the first section.  Since it was easiest, I grabbed those same vertices for the dimension reference points.  I tried using different values for the two extension line properties, but that wasn't helping me find a solution either.  (There are three distances on an extension line: the gap between the reference point and the extension line; the distance of the witness line from the reference points; and the length of extension line beyond the witness line.  Which properties control each of these distances?)
    'Draw plate plan outline
    moaShape_Points(0).X = moOrigin_PL_Plan.X: moaShape_Points(0).Y = moOrigin_PL_Plan.Y: moaShape_Points(0).Z = Z
    moaShape_Points(1).X = moaShape_Points(0).X + Lb: moaShape_Points(1).Y = moaShape_Points(0).Y: moaShape_Points(1).Z = Z
    moaShape_Points(2).X = moaShape_Points(1).X: moaShape_Points(2).Y = moaShape_Points(1).Y + Wb: moaShape_Points(2).Z = Z
    moaShape_Points(3).X = moaShape_Points(0).X: moaShape_Points(3).Y = moaShape_Points(2).Y: moaShape_Points(3).Z = Z
    Set moCurrent_Shape = CreateShapeElement1(Nothing, moaShape_Points, msdFillModeNotFilled)
    ActiveModelReference.AddElement moCurrent_Shape
    'Dimension Plate
    Dim moRot_Dim As Matrix3d
       moRot_Dim = Matrix3dIdentity
    Dim moCurrent_Dimension As DimensionElement
    Dim moCurrent_Dimension_Style As DimensionStyle
    Dim mdDim_Extension As Double
    'Create horz dimension and add end points
    Set moCurrent_Dimension = CreateDimensionElement1(Nothing, moRot_Dim, msdDimTypeSizeArrow)
    moCurrent_Dimension.AddReferencePoint ActiveModelReference, moaShape_Points(2)
    moCurrent_Dimension.AddReferencePoint ActiveModelReference, moaShape_Points(3)
    'Read Dimension style, adjust dimension property, write dimension style back.
    mdDim_Extension = 2.5   '2.5*40mm text height = 100mm offset
    Set moCurrent_Dimension_Style = moCurrent_Dimension.DimensionStyle
    moCurrent_Dimension_Style.ExtensionLineOffset = mdDim_Extension
    moCurrent_Dimension_Style.ExtensionLineExtend = mdDim_Extension
    Set moCurrent_Dimension.DimensionStyle = moCurrent_Dimension_Style
    ActiveModelReference.AddElement moCurrent_Dimension
    'Create vert dimension and add end points
    moRot_Dim = Matrix3dFromAxisAndRotationAngle(2, Pi() / 2)
    moCurrent_Dimension.AddReferencePoint ActiveModelReference, moaShape_Points(0)
    mdDim_Extension = 100   'try 100mm offset directly
I have looked at these other posts, but they weren't able to sort me out.
Dimension Offset:
http://communities.bentley.com/products/programming/microstation_programming/f/343173/p/81326/225229.aspx#225229
Dimension Text Rotation:
http://communities.bentley.com/products/programming/microstation_programming/f/343173/p/79118/217531.aspx#217531
Sample Code for CreateDimensionElement1 Function:
http://communities.bentley.com/products/programming/microstation_programming/f/19569/p/25991/59809.aspx
Dave
