What is the first version ( 08.11.09.xxxx ) of MicroStation V8i (SELECTSeries 3) available?
kaab
It is unclear what you are asking... would it be possible to clarify that? Also, is there anything in particular you need regarding that?
I'm aware that IElementGraphicsProcessor API is supported only since MicroStation V8i (SELECTSeries 3). So, I wanted to know the exact starting version of MicroStation that supports this API
The current release of MicroStation V8i (SELECTseries 3) is the one that should be used -- mainly because it is the only v08.11.09 SELECT release that can be downloaded from SELECTservices Online.
Answer Verified By: Phil Chouinard
Thank you for the information
