Concluding the following post I determined to try element color substituation in a Pen Table Hook script.
http://communities.bentley.com/products/microstation/microstation_v8i/f/19568/p/84282/236986.aspx#236986
However, I am not familiar with the old BASIC macro syntax and was hoping that somebody here could help me please?
I would like to scan element colors for specific RGB values and if found specify substitute RGB values. If not found then set the color to print Black RGB(0,0,0).
I tried various commands like follows but have not been able to get even a simple script to work.
elem.Color = ActiveModelReference.InternalColorFromRGBColor(RGB(225,225,225)
As I understand the process I "wish the element to be passed to a function in a MicroStation BASIC macro as an MbeElement... to Specify Pen Table Output Actions", where "color resymbolization is specified" as an Output Actions via this hook script such that "color resymbolizations is applied to the MbeElement object as it is passed to the BASIC function, overriding the print color.
I am also contemplating if this is simpler and would perform faster in V8i SS3 with the updated Pen Table script functionality?
This is not possible directly in MS-BASIC because it can't read RGB colors and in each file color indexes for RGB colros are different. In SS3 you can use "Design scripts" instead of pentable. But it is not compatible with older versions nor it allows to map source RGB colors. Other way would be to call VBA functions from MSBASIC plot hook macro.
I have created such function to invert RGB white to black until issue with printing RGB white is not resolved(TR 343558). It works but it is not guaranteed 100% as it works only if RGB white in DGN has either 256 OR 512 OR 1280 color index.
Function RGB_W2B (elm as MbeElement) As LongDim linkArray(1 To 3) As IntegerDim patternlinkArray(3 to 51) 'As Integer' print elm.color status = elm.extractLinkage (linkArray, 65) 'try to extract fill attribute If status = 0 AND elm.isGraphics AND (elm.color=512 OR elm.color=1280) Then linkArray(1) = 8 linkArray(2) = 0 linkArray(3) = 0 ' color is an Integer stat=elm.deleteLinkage(65,-1) 'delete old linkage stat=elm.appendLinkage(linkArray,65) 'recreate new linkage ' stat=elm.rewrite() End Ifstatus = elm.extractLinkage (patternlinkArray, 32040) 'try to extract patter attribute If status = 0 AND elm.isGraphics AND (elm.color=512 OR elm.color=1280) Then patternlinkArray(17) = 0 ' color is an Integer patternlinkArray(18) = 0 ' color is an Integer stat=elm.deleteLinkage(32040,-1) 'delete old linkage stat=elm.appendLinkage(patternlinkArray,32040) 'recreate new linkage ' stat=elm.rewrite() End If'MbeSendCommand "co=RGB:255:255:255"'elm.color = MbeSettings.color If elm.color=256 then elm.color=0 If elm.color=512 then elm.color=0If elm.color=1280 then elm.color=0 RGB_W2B = MBE_ElemNormal End Function
Attaching also a Design script which is easier to use. Tried to use it for HTML Author tool but didn't work.
Regarding design scripts same issue as before, it doesn't allow to map RGB to RGB, only index colors to RGB.
Thanks Oto :)
Due to the problematic nature of using 'full' True colour for all layer/printing requirements, I dropped the approach and am predominantely using colour tables again. There are just too many issues and bugs with the use of True Colour for everything.
Time goes on but still this issue is not resolved and even if it will be it won't be backwards compatible.
So attaching latest pentable hook macro which I now hacked to work with RGB colors. At least RGB white to black prints ok.
Type MbeRGB R As integer G As integer B As integer End Type sub main End Sub Function RGB_W2B (elm as MbeElement) As Long Dim linkArray(1 To 3) As Integer Dim patternlinkArray(3 to 51) 'As Integer dim ElemRGBcolor as MbeRGB ' print elm.color 'MbeSendCommand "co=RGB:255:255:255" ''elm.color = MbeSettings.color ' If elm.color=256 then elm.color=0 ' If elm.color=512 then elm.color=0 'If elm.color=1280 then elm.color=0 status = MbeCExpressionLong ("tcb->uc_i[1]="&cstr(elm.color)) 'set uc_i[1] register to element color 'status = MbeCExpressionString ("mdlModelRef_getActive()") 'MASTERFILE modelref 'status = MbeCExpressionString ("mdlModelRef_getDgnFile(mdlModelRef_getActive())") 'DgnFileP status2$ = MbeCExpressionString ("mdlColor_elementColorToRGB (" + _ "&tcb->uc_i[0]," + _ "((void *)0)," + _ "mdlModelRef_getActive()," + _ "tcb->uc_i[1]," + _ "((void *)0)" + _ ")") ' status$ = MbeCExpressionString ("mdlColor_elementColorToRGBInFile (" + _ ' "&tcb->uc_i[0]," + _ '' "mdlModelRef_getDgnFile(mdlModelRef_getActive())," + _ '' "1," + _ '' "((void *)0)" + _ '' ")") '' status$ = MbeCExpressionString ("mdlColor_rawColorFromRGBColor (" + _ '' "&tcb->uc_i[1]," + _ '' "&tcb->uc_i[0]," + _ '' "mdlModelRef_getActive()" + _ '' ")") '' rawcolor$ = MbeCExpressionString ("tcb->uc_i[1]") elemRGBcolor.R = MbeCExpressionLong("(unsigned char)(tcb->uc_i[0])&(0xffL)") elemRGBcolor.G = MbeCExpressionLong("((unsigned char)(tcb->uc_i[0])>>8) & (0xffL)") elemRGBcolor.B = MbeCExpressionLong("((unsigned char)(tcb->uc_i[0])>>16) &(0xffL)") status = elm.extractLinkage (linkArray, 65) 'try to extract fill attribute If status = 0 AND elm.isGraphics AND (elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255) Then linkArray(1) = 8 linkArray(2) = 0 linkArray(3) = 0 ' color is an Integer stat=elm.deleteLinkage(65,-1) 'delete old linkage stat=elm.appendLinkage(linkArray,65) 'recreate new linkage ' stat=elm.rewrite() End Ifstatus = elm.extractLinkage (patternlinkArray, 32040) 'try to extract patter attribute If status = 0 AND elm.isGraphics AND (elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255) Then patternlinkArray(17) = 0 ' color is an Integer patternlinkArray(18) = 0 ' color is an Integer stat=elm.deleteLinkage(32040,-1) 'delete old linkage stat=elm.appendLinkage(patternlinkArray,32040) 'recreate new linkage ' stat=elm.rewrite() End IfIf elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255 then elm.color=0 'print elm.color RGB_W2B = MBE_ElemNormal End Function
Updated version as previous version didn't correctly remap elements in reference files
Type MbeRGB R As integer G As integer B As integer End Type sub main End Sub Function RGB_W2B (elm as MbeElement) As Long Dim linkArray(1 To 3) As Integer Dim patternlinkArray(3 to 51) 'As Integer dim ElemRGBcolor as MbeRGB status = MbeCExpressionLong ("tcb->uc_i[1]="&cstr(elm.color)) 'set uc_i[1] register to element colorstatus3$ = MbeCExpressionString ("tcb->uc_a[0]="&cstr(elm.fileNum)) 'set uc_a[0] register to element ref number status2$ = MbeCExpressionString ("mdlColor_elementColorToRGB (" + _ "&tcb->uc_i[0]," + _ "((void *)0)," + _ "tcb->uc_a[0]," + _ "tcb->uc_i[1]," + _ "((void *)0)" + _ ")") elemRGBcolor.R = MbeCExpressionLong("(unsigned char)(tcb->uc_i[0])&(0xffL)") elemRGBcolor.G = MbeCExpressionLong("((unsigned char)(tcb->uc_i[0])>>8) & (0xffL)") elemRGBcolor.B = MbeCExpressionLong("((unsigned char)(tcb->uc_i[0])>>16) &(0xffL)")'Check element fill status = elm.extractLinkage (linkArray, 65) 'try to extract fill attribute If status = 0 AND elm.isGraphics AND (elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255) Then linkArray(1) = 8 linkArray(2) = 0 linkArray(3) = 0 ' color is an Integer stat=elm.deleteLinkage(65,-1) 'delete old linkage stat=elm.appendLinkage(linkArray,65) 'recreate new linkage End If'Check pattern colorstatus = elm.extractLinkage (patternlinkArray, 32040) 'try to extract patter attribute If status = 0 AND elm.isGraphics AND (elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255) Then patternlinkArray(17) = 0 ' color is an Integer patternlinkArray(18) = 0 ' color is an Integer stat=elm.deleteLinkage(32040,-1) 'delete old linkage stat=elm.appendLinkage(patternlinkArray,32040) 'recreate new linkage End IfIf elm.color>255 AND elemRGBcolor.R=255 AND elemRGBcolor.G=255 AND elemRGBcolor.B=255 then elm.color=0 RGB_W2B = MBE_ElemNormal End Function
the only vba version I could find is here
http://communities.bentley.com/products/microstation/w/microstation__wiki/22616.how-to-read-the-rgb-values-of-the-attached-color-table
but its not as good as the old bas Draw colour updated ( attached) as that does export to txt as well as create graphical swatches are very helpfull printed out to see final result on paper or pdf good for calibration of printers and comparison of all sorts of issues...
if your using v8i you can still use the attached old bas and work out what needs changing to make a new colour table...from the prints or txtColortbl2txt.zip
Lorys
What we do is use RGB values instead of indexed colors and that is where lot of problems arise. Microstation uses RGB colors and element templates but the implementation is far from perfect. In CONNECT edition it is now possible to use VBA for remapping - communities.bentley.com/.../381478 But I still miss simple functionality as VBA is not reliable and overkill for just simple purpose. MSBASIC and Pentables/Design script just work but VBA depends on external libraries which can fail after any Windows Update or MS Office installations also depends on regional settings, Windows language, Windows version. Users do not expect that printout preparation rely heavily on macros so it should be transparent and trouble free.
